Old 10-08-2015, 03:40 PM   #141
maca
Drives: brz
take a look for 1320 Performance UEL Headers and Overpipe
http://www.ft86club.com/forums/showp...1&postcount=19
6.30kg (13.89 lbs) for headers,
1.42kg ( 3.13 lbs) for Overpipe
maca is offline   Reply With Quote
Old 10-20-2015, 09:45 AM   #142
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Thank you, sir. Updated.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 07-17-2016, 06:52 PM   #143
Chenjovi
Drives: 2012 GT86
hey guys, if you want to add the OFH headers to the list weight was in KG which works out to be approx 10.5lbs - i also have the overpipe but did not even register on the scale.
Chenjovi is offline   Reply With Quote
The Following 2 Users Say Thank You to Chenjovi For This Useful Post:
Anthony (08-23-2016), yberther (07-18-2016)
Old 11-30-2016, 01:48 AM   #144
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
Anybody have the weight of the HKS Dual Resonated Front Pipe? I have the Tomei Unreonated Front Pipe that weighs 3lbs. Which is 9lbs lighter than stock. It's too loud for me though so I'm trying to get a quite lightweight front pipe that's resonated. Looking into the HKS Dual type. I tried looking for a resonated titanium front pipe but couldn't really find one so I'm considering HKS, I'm just afraid it being dual resonated it'll weigh a lot.
nova.86 is offline   Reply With Quote
Old 06-01-2017, 10:11 AM   #145
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Anybody know which of the catbacks below 30lbs is the tamest? i.e. least loud?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 06-02-2017, 01:45 PM   #146
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Least loud for me my Perrin 2.5 resonated but it's 33 pounds.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 06-02-2017, 02:12 PM   #147
Icecreamtruk
Drives: Track preped NA FRS
TRD is pretty tame as well, its around 30-32 lbs if I remember correctly.
Icecreamtruk is offline   Reply With Quote
Old 09-28-2017, 06:20 PM   #148
MileMonger
MileMonger's Avatar
Drives: 2015 Subaru BRZ
Possibly the Q300, but it's 39 lbs. I hear the nameless Axleback is pretty quiet too and you can mate it with a light midpipe.
OP, the FT86speedfactory UEL catted headers are 13.0 lbs, as per: http://www.ft86speedfactory.com/ft86...E#.Wc10Yp8pDqA
Sent from my SM-G930T using Tapatalk
MileMonger is offline   Reply With Quote
Old 09-28-2017, 08:08 PM   #149
DAEMANO
Time Traveller
Not to jump on the hype train, but I think the ACE Laguna 90 is 32 lbs and designed to be super quiet at WOT. They quote 90db at 6k RPM which would be damn quiet for an aftermarket exhaust running wide open.
http://www.aceheader.com/index.php/p...-system-detail
Old 11-26-2017, 07:33 PM   #150
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
My Blitz Nur-Spec VSR dual exhaust weighs 35lbs if it can be added.
[ame]http://youtu.be/sQP1YXCU3UA?t=4m35s[/ame]
justinco is offline   Reply With Quote
Old 01-12-2018, 03:12 AM   #151
Chriswongbrz
Drives: 2015 brz
Theres a lot of headers and exhaust that’s not on there like the tomei and ace or anaconda
Originally Posted by Anthony View Post
Thanks everybody who's contributed information. If you would like to add information, please link your source of information, or better yet: post a photo of the part on a scale like in the official weight thread. If you don't give me a source, I will use your post as the source. We're thorough around here!
I've also decided to color code parts by diameter. Matching colors = less turbulence = minimized loss of horsepower
2.118"/53.8mm, 2.25"/57.15mm 2.36"/60mm, 2.38"/60.5mm, 2.5"/63.5mm, 2.76"/70.1mm, 3.15"/80mm Unknown
***Note that some measurements may be inner diameter, and some may be outer diameter. Check your sources if diameter is a concern to you, which it should be if you want hp/tq gains***
Headers:
30.00lbs - FA20Club (Source)
21.10lbs - Greddy Catted (Source)
20.90lbs - Stock (Source)
16.30lbs - Greddy Catless (Source)
14.00lbs - Hotpipes Forceworks UEL Header (Source)
13.89lbs - 1320 UEL (Source)
13.65lbs - HKS EL (Source)
13.00lbs - JDL (Source)
12.65lbs - T1R (Source)
12.00lbs - Rev Works (Source)
10.90lbs - Nameless Stepped 1.500-1.625 Catted (Source)
10.20lbs - Borla UEL (Source)
Over Pipes:
11.4lbs - Nameless Over/Front Pipe Combo catted resonated (Source)
6.70lbs - Borla Cat Delete Pipes (Front & Over combo) (Source)
4.50lbs - Stock (Source)
3.50lbs - Milltek Sport (Source)
3.50lbs - Perrin (Source)
3.13lbs - 1320 (Source)
3.00lbs - PLM Overpipe (Source)
2.94lbs - Avo Turbo World ceramic coated (Source)
Front Pipes:
12.2lbs - Stock (Source)
09.0lbs - Avo Turbo World catted (Source)
07.8lbs - Tsudo (Source)
07.2lbs - Invidia catless resonated (Source) (Diameter)
07.0lbs - PLM with high flow cat (Source)
06.7lbs - Borla Cat Delete Pipes (Front & Over combo) (Source)
05.2lbs - T1R (Source: PM from FT-86 SpeedFactory)
03.1lbs - Tomei (Source)
02.2lbs - Amuse (Source)
Mid Pipes:
12.40lbs - Stock (Source)
12.35lbs - Tsudo (Source)
08.60lbs - Invidia as used on N1 and Q300 (Source) (Diameter)
07.50lbs - Tommy Kaira Titanium (Source)
Catback Exhausts:
40.80lbs - MXP Prototype (Source)
39.00lbs - Invidia Q300 (Source) (Diameter)
38.50lbs - Stock (Source) (Diameter)
36.60lbs - HKS Legamax Premium (Source)
36.40lbs - Magnaflow (Source)
34.80lbs - GReddy EVO3 (Source)
33.95lbs - Tsudo (Source)
33.60lbs - Isis Street (Source)
33.60lbs - Perrin Dual Single Tip (Source)
33.40lbs - Berk (Source)
33.00lbs - TRD USA (Source) (Diameter?)
31.00lbs - Milltek Sport Resonated (Source)
30.80lbs - GReddy/TRUST CS GTS V2 (Source)
29.20lbs - Dezod Motorsports Dual Exit (Source)
29.00lbs - Invidia N1 (Source) (Diameter)
28.00lbs - Milltek Sport Non-Resonated (Source)
28.00lbs - Borla (Source)
26.00lbs - FT86SpeedFactory V2 (Source)
25.20lbs - Agency Power (Source)
22.00lbs - HKS Hi-Power (Source) (Diameter)
22.00lbs - Tanabe Concept G (Source) (Diameter)
21.60lbs - Tommy Kaira Titanium (Source)
18.00lbs - Buddy Club Spec II (Source) (Diameter)
17.08lbs - This Thing
16.53lbs - Panda Performance Titanium (Source)
16.10lbs - Tomei 80 (Source)
15.43lbs - TO-YO-07 (Source)
14.10lbs - Tomei 60S (Source)
<12.0lbs - T1R 70RT Titanium (Limited time group buy, get it while you can!)
10.20lbs - Tomei 60R (Source) Although mine weighs 9.98lbs - photo
09.70lbs - STM Aluminum Dual Exit (Source)
08.40lbs - Amuse R1000 Single Exit (Source)
Based on all this information, the factory engine back system weighs 76.1lbs. The current lightest combination is:
Borla UEL headers, Avo over pipe, Amuse front and catback sytem for a total of 23.74lbs, saving 52.36lbs from stock.
Chriswongbrz is offline   Reply With Quote
Old 01-13-2018, 05:12 PM   #152
Anthony
Weight Nazi
Anthony's Avatar
Where in the video does it say the weight?
Just get me the info.
Old 01-13-2018, 09:03 PM   #153
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Right at the time that I linked. I weighed both exhaust parts right before that.
Old 01-14-2018, 04:27 PM   #154
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
This was done a few years ago. If you know the weights post them.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Anthony (01-15-2018)
Borla UEL headers + HKS Front pipe + Greddy SP AxleBack = music sounds to my ears. NoFear99 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 09-22-2013 11:02 PM
FS: OEM Exhaust and Mid and front pipe Bcarlos Engine, Exhaust, Bolt-Ons 3 07-24-2013 05:16 PM
Exhaust,test pipe, over pipe, headers, or suspension build ShikoBariki Engine, Exhaust, Transmission 20 05-01-2013 04:16 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
