Old 07-25-2013, 05:13 AM   #1
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Post Lightest Exhaust, Headers, and Front/Over/Mid Pipes?
Thanks everybody who's contributed information. If you would like to add information, please link your source of information, or better yet: post a photo of the part on a scale like in the official weight thread. If you don't give me a source, I will use your post as the source. We're thorough around here!
I've also decided to color code parts by diameter. Matching colors = less turbulence = minimized loss of horsepower
2.118"/53.8mm, 2.25"/57.15mm 2.36"/60mm, 2.38"/60.5mm, 2.5"/63.5mm, 2.76"/70.1mm, 3.15"/80mm Unknown
***Note that some measurements may be inner diameter, and some may be outer diameter. Check your sources if diameter is a concern to you, which it should be if you want hp/tq gains***
Headers:
30.00lbs - FA20Club (Source)
21.10lbs - Greddy Catted (Source)
20.90lbs - Stock (Source)
16.30lbs - Greddy Catless (Source)
14.00lbs - Hotpipes Forceworks UEL Header (Source)
13.89lbs - 1320 UEL (Source)
13.65lbs - HKS EL (Source)
13.00lbs - JDL (Source)
12.65lbs - T1R (Source)
12.00lbs - Rev Works (Source)
10.90lbs - Nameless Stepped 1.500-1.625 Catted (Source)
10.20lbs - Borla UEL (Source)
Over Pipes:
11.4lbs - Nameless Over/Front Pipe Combo catted resonated (Source)
6.70lbs - Borla Cat Delete Pipes (Front & Over combo) (Source)
4.50lbs - Stock (Source)
3.50lbs - Milltek Sport (Source)
3.50lbs - Perrin (Source)
3.13lbs - 1320 (Source)
3.00lbs - PLM Overpipe (Source)
2.94lbs - Avo Turbo World ceramic coated (Source)
Front Pipes:
12.2lbs - Stock (Source)
09.0lbs - Avo Turbo World catted (Source)
07.8lbs - Tsudo (Source)
07.2lbs - Invidia catless resonated (Source) (Diameter)
07.0lbs - PLM with high flow cat (Source)
06.7lbs - Borla Cat Delete Pipes (Front & Over combo) (Source)
05.2lbs - T1R (Source: PM from FT-86 SpeedFactory)
03.1lbs - Tomei (Source)
02.2lbs - Amuse (Source)
Mid Pipes:
12.40lbs - Stock (Source)
12.35lbs - Tsudo (Source)
08.60lbs - Invidia as used on N1 and Q300 (Source) (Diameter)
07.50lbs - Tommy Kaira Titanium (Source)
Catback Exhausts:
40.80lbs - MXP Prototype (Source)
39.00lbs - Invidia Q300 (Source) (Diameter)
38.50lbs - Stock (Source) (Diameter)
36.60lbs - HKS Legamax Premium (Source)
36.40lbs - Magnaflow (Source)
34.80lbs - GReddy EVO3 (Source)
33.95lbs - Tsudo (Source)
33.60lbs - Isis Street (Source)
33.60lbs - Perrin Dual Single Tip (Source)
33.40lbs - Berk (Source)
33.00lbs - TRD USA (Source) (Diameter?)
31.00lbs - Milltek Sport Resonated (Source)
30.80lbs - GReddy/TRUST CS GTS V2 (Source)
29.20lbs - Dezod Motorsports Dual Exit (Source)
29.00lbs - Invidia N1 (Source) (Diameter)
28.00lbs - Milltek Sport Non-Resonated (Source)
28.00lbs - Borla (Source)
26.00lbs - FT86SpeedFactory V2 (Source)
25.20lbs - Agency Power (Source)
22.00lbs - HKS Hi-Power (Source) (Diameter)
22.00lbs - Tanabe Concept G (Source) (Diameter)
21.60lbs - Tommy Kaira Titanium (Source)
18.00lbs - Buddy Club Spec II (Source) (Diameter)
17.08lbs - This Thing
16.53lbs - Panda Performance Titanium (Source)
16.10lbs - Tomei 80 (Source)
15.43lbs - TO-YO-07 (Source)
14.10lbs - Tomei 60S (Source)
<12.0lbs - T1R 70RT Titanium (Limited time group buy, get it while you can!)
10.20lbs - Tomei 60R (Source) Although mine weighs 9.98lbs - photo
09.70lbs - STM Aluminum Dual Exit (Source)
08.40lbs - Amuse R1000 Single Exit (Source)
Based on all this information, the factory engine back system weighs 76.1lbs. The current lightest combination is:
Borla UEL headers, Avo over pipe, Amuse front and catback sytem for a total of 23.74lbs, saving 52.36lbs from stock.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Last edited by Anthony; 10-20-2015 at 10:45 AM. Reason: Adding new information as it arrives.
Anthony is offline   Reply With Quote
The Following 64 Users Say Thank You to Anthony For This Useful Post:
37 (07-26-2013), 86 South Africa (10-18-2015), aagun (12-26-2013), adprokid (11-04-2013), Ammunition (09-07-2014), androopoo (04-01-2015), Black Tire (02-23-2015), BlueDubbinTDI (12-30-2013), Bonburner (10-28-2018), BrianJC (08-06-2013), Brinks (08-07-2014), Bykov (05-16-2018), CajunFRS (09-12-2013), calmtigers (12-04-2013), Captain Snooze (07-25-2013), conehead (09-25-2019), diss7 (07-27-2013), Donbrz (03-11-2015), D_Thissen (07-08-2015), Enraged21 (11-30-2013), flippy (07-26-2013), fstlane (10-13-2013), FT86Z (06-04-2018), FT_86_SM_GP (04-21-2015), garfull (10-05-2013), Hawk77FT (08-02-2013), jdmasfcuk (09-19-2013), JiB (07-25-2013), JMon85 (03-09-2018), juliog (08-10-2013), kalamitykode (12-26-2015), Keenercarguy (04-03-2016), Lawnik (12-04-2013), Luckrider (06-29-2014), mad_sb (09-07-2013), Mikem53 (12-17-2013), Mr.Jay (09-24-2013), mwjcyber (09-07-2013), new2subaru (11-07-2015), NWFRS (08-01-2014), onabulletride (01-08-2014), pcuerpo (11-27-2013), Pekingduck (07-05-2015), philooo (07-05-2015), raul (08-14-2013), RehabJeff86 (12-01-2013), rookietopro_frs (10-12-2017), s2d4 (08-01-2013), ShibusaTouge (12-15-2017), Sithspawn (08-03-2013), SuperTom (04-22-2018), supra2nv (11-11-2015), supramkivtt2jz (07-26-2013), Teseo (01-30-2015), tgat86 (01-21-2015), tigermack (09-17-2014), Tristor (05-29-2018), trustyler (11-15-2013), ultra (08-01-2013), Uplink (03-12-2015), Valentino (05-26-2015), WRB-DZA-BRZ (09-04-2013), YMAA (09-07-2013), zephyr69 (07-25-2013)
Old 07-25-2013, 06:41 AM   #2
Anthony
Weight Nazi
Anthony's Avatar
I've also emailed two titanium exhaust manufacturers. I know a one-off titanium exhaust would be ungodly expensive and probably not worth the weight savings, even for me, but maybe a group buy could make it reasonable.
The Following User Says Thank You to Anthony For This Useful Post:
juliog (08-10-2013)
Old 07-25-2013, 06:43 AM   #3
coupeae86
Drives: 2013 FRS 1986 Corolla GTS
38.5lbs - stock
35lbs - GReddy EVO3
22lbs - HKS Hi-Power
22lbs Tanabe Concept G
33lbs - TRD USA
coupeae86 is offline   Reply With Quote
The Following User Says Thank You to coupeae86 For This Useful Post:
Anthony (07-25-2013)
Old 07-25-2013, 06:44 AM   #4
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
http://www.ft86club.com/forums/showthread.php?t=27092 <-borla header & perrin overpipe
http://www.ft86club.com/forums/showthread.php?t=9179 <- nameless header
http://www.ft86club.com/forums/showthread.php?t=30936 <-Rev works header
http://www.ft86club.com/forums/showthread.php?t=21076 <- JDL Headers/Exhaust system total weight loss 40lbs.
http://www.ft86club.com/forums/showthread.php?p=597493 <-^
https://www.privatelabelmfg.com/category_s/63.htm <- PLM Overpipe / Frontpipe w/ high flow cat
Borla header 10.2lbs
perrin overpipe 3.5lbs
nameless header 10.9-11.6lbs
rev works header 12lbs
JDL Headers/Exhaust -40lbs total
PLM Overpipe 3lbs
PLM front pipe with high flow cat 7lbs
The Following User Says Thank You to midnight23 For This Useful Post:
Old 07-25-2013, 06:48 AM   #5
Anthony
Weight Nazi
Anthony's Avatar
Originally Posted by coupeae86 View Post
38.5lbs - stock
I suppose this is the weight of the stock exhaust from the cat back?
Old 07-25-2013, 07:01 AM   #6
Anthony
Weight Nazi
Anthony's Avatar
Thanks, midnight23! Updated OP. But...
Originally Posted by midnight23 View Post
"Invalid Thread specified. If you followed a valid link, please notify the administrator"
Old 07-25-2013, 07:02 AM   #7
midnight23
Probably because the headers alone are 20lbs
Old 07-25-2013, 07:02 AM   #8
Anthony
Weight Nazi
Anthony's Avatar
Weird. When I click on it in the link where I quoted you, it works. But when I click on your link in your original post, I get the message.
86socal (08-07-2014)
Old 07-25-2013, 07:03 AM   #9
midnight23
Weird, I am able to load that thread without issues.
Old 07-25-2013, 07:04 AM   #10
midnight23
Try now, it didn't correct the URL link, only the text link when I made some adjustments before hand, the url link should now be correct
Old 07-25-2013, 07:10 AM   #11
Anthony
Weight Nazi
Anthony's Avatar
38.5lbs - stock
35lbs - GReddy EVO3
33lbs - TRD USA
Thanks. I'm listing you as the source on these numbers. I got the same number from Tanabe's website, so I'll use that for that source. Get me some links and I'll update.
Old 07-25-2013, 07:57 AM   #12
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Hotpipes Forceworks UEL 4-1 Header - 14lbs
Blighty is offline   Reply With Quote
The Following User Says Thank You to Blighty For This Useful Post:
Old 07-25-2013, 08:53 AM   #13
Captain Insano
Thanks for this thread. A topic near and dear to my heart.
Invidia Q300 = 39
Invidia N1 = 29
The Following User Says Thank You to Captain Insano For This Useful Post:
Old 07-25-2013, 09:06 AM   #14
Anthony
Weight Nazi
Anthony's Avatar
Invidia Q300 = 39
Invidia N1 = 29
Gooo! Heavy. Thanks, added.
Borla UEL headers + HKS Front pipe + Greddy SP AxleBack = music sounds to my ears. NoFear99 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 09-23-2013 12:02 AM
FS: OEM Exhaust and Mid and front pipe Bcarlos Engine, Exhaust, Bolt-Ons 3 07-24-2013 06:16 PM
Exhaust,test pipe, over pipe, headers, or suspension build ShikoBariki Engine, Exhaust, Transmission 20 05-01-2013 05:16 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 01:29 PM
