Old 05-14-2015, 10:49 AM   #141
Streetthrowback
Drives: 2015 brz
if one wanted to buy this kit does one need to buy a ecutek? is a tune needed?
Streetthrowback is offline
Old 05-14-2015, 01:30 PM   #142
kch
Senior Misanthrope
kch's Avatar
Yes, you will need the kit + ecutek license + tune + cable (which you could maybe borrow)
Edit: looks like moto-east includes a tune with their kit. But you'll still need a license and cable.
kch is offline
The Following User Says Thank You to kch For This Useful Post:
Streetthrowback (05-15-2015)
Old 05-15-2015, 11:09 AM   #143
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
@moto-mike, I've got everything installed and flashed your first tune! I've emailed you back yesterday with a few logs, hopefully you saw them!
pgranberg11 is offline
The Following User Says Thank You to pgranberg11 For This Useful Post:
Xero-Limit (05-15-2015)
Old 05-22-2015, 09:56 PM   #144
YEAHdams
Drives: 2013 frs 10series
Got everything up and running. Holy sweetness this is awesome.
YEAHdams is offline
The Following User Says Thank You to YEAHdams For This Useful Post:
Xero-Limit (06-15-2015)
Old 06-15-2015, 08:00 AM   #145
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
A little update for folks running these kits with FI and bigger injectors. We've identified an issue with the DW700 pigtails that everyone has been running, and the pins have been a little short on some. So if you've had issues with intermittent injector codes, that is almost certainly the issue. DW identified this problem apparently shortly before we did, and they already have the adapters ready to go. We have a few dozen here to support those that have bought injectors from us, we'll mail them out free of charge if you've had the issues (until we run out). Otherwise please contact deatschwerks if you have this problem and they will get them out to you. We made the announcement on FB last week but we understand not everyone gets that.
Xero-Limit is offline
The Following User Says Thank You to Xero-Limit For This Useful Post:
IBill4You (06-15-2015)
Old 06-15-2015, 02:34 PM   #146
Fiskafan
Drives: Toyta GT86
Originally Posted by moto-mike View Post
Our solution to this is as follows:
With our flex fuel tune you can select the VSC button to sport, and that will trigger a "learning mode" where both PI and DI will fire at low loads/rpms. Once you see the ECA stop moving you know that the fuel has pretty much fully circulated. Then you are good to go. We are also going to probably implement this so the first 120 seconds of the car being on it does this too. But we're waiting on EcuTek to fix a bug we found. Should be done shortly. Then you only would trigger the mode if you're not restarting the car or if it needs more time.
Need some help regarding this... I have performed a couple of fill ups with different fuel mixture now and its mostly very slow with updating the Ethanol content.
When doing EcuTek logging, PI and DI does not seem to be affected on idle when pressing "VSC Button". Only one of the lines seems to be used. When the engine is cold and i start it, then i do see that both lines are used until it revs down. when the engine is warm then i can't see that it uses both lines at engine start.
I have noticed that PI and DI seems to be used almost the same amount when cruising at 2500rpm. Once i go up to somewhere around 3000 RPM then it seems to only use one of the lines.
So, i hope that someone can help me with which method is the correct one to apply when switching between gas/ethanol? Is it the VSC button or is it cruising along at around 2500 RPMs until the ethanol reading is stable?
Thanks!
Fiskafan is offline
Old 06-15-2015, 03:11 PM   #147
Xero-Limit
Xero-Limit's Avatar
Thanks!
We need to update the post with that info. You'll want to go to mode 2 on your map, then select the TC FULLY off. That will temporarily trip the CEL light so you can see it is active. Give it a go.
Old 06-15-2015, 03:27 PM   #148
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Do you have any DW 700cc in stock? I assume these are plu and play?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline
Old 06-15-2015, 03:28 PM   #149
Fiskafan
Drives: Toyta GT86
Excellent!
So, next question then... How do I select mode without "RaceROM"? Pulling the cruise control against me for 3 seconds does not engage it. My Rev meter does not indicate a map.
Thanks once again!
Fiskafan is offline
Old 06-15-2015, 10:25 PM   #150
Xero-Limit
Xero-Limit's Avatar
Excellent!
Thanks once again!
Will double check and get back to you there. We had to make that ROM from scratch using the latest RR revision and it being a euro ROM, so it is not entirely impossible that we just need to enable the modes.
No and Yes. We have 4 more sets due in on friday. We can drop ship them if you need a set sooner.
Old 06-17-2015, 08:00 PM   #151
onzippy
Drives: 2014 FRS
Don't know if anyone is keeping track but another satisfied customer here with @moto-mike and his flex fuel kit.
Quality of the kit is right on par with his Tuning ninja skills and no one should expect anything less.
If you're unfortunate enough to have to exercise a little patience because of his busy schedule dont be discouraged. I've shopped elsewhere and can tell you his product and skills are worth the wait....that's even if you have to wait. I didn't so lucky me
Thanks Mike. Great stuff. Love 'n it.
onzippy is offline
The Following User Says Thank You to onzippy For This Useful Post:
Xero-Limit (06-18-2015)
Old 06-28-2015, 06:36 AM   #152
Fiskafan
Drives: Toyta GT86
Another satisfied customer. Have been running the Moto-East flex fuel tune for about a month and it's working great.
Ive also managed "peak" at e85
Fiskafan is offline
Old 06-28-2015, 12:47 PM   #153
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
^^^^^ what app is that?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline
Old 08-08-2015, 10:32 PM   #154
Astroboy
Astroboy's Avatar
Drives: None
Would a tune be required if I were to install the M E flex fuel kit....? I've already installed a turbo and already had it dyno tuned, but I don't want to have to install it and get it tuned right a way...I want to install it, and then get it re tuned once I have the time
Sent from my LG-D850 using Tapatalk
Astroboy is offline
e85, ethanol, flex fuel
Moto-East (Moto Mike) Review Thread ecko04 User/Vendor/Sponsor Reviews, Feedback, Comments 4 05-22-2014 07:57 PM
GReddy Turbo Kit Now Available at Moto-East! Xero-Limit Forced Induction 1 12-27-2013 02:20 PM
Moto-East E85 Testing Xero-Limit Engine, Exhaust, Transmission 11 07-23-2013 04:55 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
Moto-East tune -wow Evil86 Engine, Exhaust, Transmission 2 03-13-2013 02:02 PM
