Old 05-18-2015, 01:52 PM   #15
IBill4You
Drives: 2015 Subaru BRZ
A new tune corrected the issue. I was told it may be something with the 2015 being different than the other models. I honestly couldn't care any less at this point because I can finally drive again. My lesson was that once I tried all the obvious things it was time to give it to a professional to fix.
IBill4You is offline   Reply With Quote
The Following User Says Thank You to IBill4You For This Useful Post:
aagun (05-18-2015)
Old 05-18-2015, 03:25 PM   #16
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I dont think anything has changed. Sounds like an excuse for the bad initial tune. Glad to hear you are up and running again
2much is offline   Reply With Quote
The Following User Says Thank You to 2much For This Useful Post:
aagun (05-18-2015)
Old 05-19-2015, 12:06 AM   #17
IBill4You
I totally understand where you're coming from, and I admittedly do not know for certain. I have dealt with two different tuners and have way too many variables from dealing with either one to make a judgement call beyond customer service. I am very satisfied by the level of service I received by all parties involved. My big takeaway is that I am over my head as a DIYer trying to mess with installing and tuning forced induction on a car. Maybe you will be smarter/luckier than I was. Maybe I caused these issues by install error/order error/flash procedure error maybe it was a bad tune. The only thing that I am certain of is that I just don't have the time to mess with guesswork because I need to have two operable vehicles ASAP so I can sell my old DD to buy an engagement ring for the old lady before the rest of my hair falls out and/or my gut gets any bigger
If I had more time to find and digest information then things could've been different, but here I am with more money than brains because I have invested 95% of my life (for better or worse) to working to earn money. I wish I could have more leisure time to learn to handle these things, however from an economics standpoint I should just continue to do what I know until I have enough $ to pay other people to do things correctly the first time for me for a fair price.
CSG Mike (05-19-2015)
Old 05-19-2015, 01:01 AM   #18
2much
I wanna go fast
You sound like you know what you're doing.
Old 05-19-2015, 02:28 AM   #19
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
after looking at your log, the MAF scaling was way off. The advance timing looks odd, and the pump pressure is weird, and your AFR is wacky. Bad initial tune, is my guess.
But it also looks like I'm late to the party, damn
Old 05-19-2015, 10:22 AM   #20
IBill4You
I don't know if this will make a difference or if someone more experienced can chime in but is a reflash required when a bad map sensor is replaced? I had an issue in the past that a reflash corrected. I also found that allowing the car to idle and sort of get used to the tune made a difference as well. Any thoughts? I am waiting for my air oil separator to come in the mail, but I am going to do some more playing around with this now that I have my new DD at least "safe enough" to drive at this point.
Old 05-19-2015, 04:58 PM   #21
aagun
Drives: 86
from the log that idle is so bad . and it jump to me rich fuel . it should stay at 14.7 close loop
aagun is offline   Reply With Quote
Old 05-29-2015, 09:49 AM   #22
Illuminaughty
Drives: 2013 Subaru BRZ Limited 6MT
I know this was like ten days ago but I noticed nobody's answered. If you scaled your MAP sensor in the tune using your bad sensor then yes you'd need to rescale with the good sensor then reflash. If you never scaled it to your specific sensor then you're (probably) good to go without a reflash.
Illuminaughty is offline   Reply With Quote
The Following User Says Thank You to Illuminaughty For This Useful Post:
IBill4You (05-29-2015)
Fuel trims abnormal after cleaning intake. feldy Engine, Exhaust, Transmission 8 04-16-2014 04:48 PM
Fuel trims video mike_ekim1024 Software Tuning 1 12-20-2013 08:01 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 08:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
