Old 08-25-2013, 06:51 PM   #1
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
long term and short term
Just had a quick question. When it comes to long term and short term fuel ratios, where should they ideally be at? can an intake affect the numbers?
brichard0625 is offline   Reply With Quote
Old 08-25-2013, 06:57 PM   #2
Ross
Drives: 85 corolla gts
For long terms I shoot for 0, for short term I personally like to see no more the +3 to -3 tighter is preferred if possible as that is a 6% swing
Ross is offline   Reply With Quote
Old 08-25-2013, 07:21 PM   #3
brichard0625
thank you...i wanna check my logs now that im on a stock tune because on ecutek tune my short term was like 8-16% my long term was like 0-2%
Old 08-25-2013, 08:14 PM   #4
arghx7
Drives: car
stock car, stock tune? Pretty whatever's it's at is fine unless you're throwing a code or something. It's a self-learning system and every engine is in a different condition.
arghx7 is offline   Reply With Quote
Old 08-25-2013, 08:31 PM   #5
brichard0625
stock car and i am throwing a code. p0420..waiting for toyota to see if they can change the header for me.
Old 08-26-2013, 01:02 AM   #6
ft_sjo
Drives: GT86
P0420 can also get directly triggered by a lean running condition, not just catalyzer efficiency.
Old 08-26-2013, 08:45 AM   #7
brichard0625
I've checked everything and put everything back to stock. My last guess is cat in header. Just trying to figure it out if it could be my drop in filter. Im sure it cant be that but who knows..the code comes and goes...it stays on for a week and shuts off for a week and then comes back by itself again.
Old 08-26-2013, 08:56 AM   #8
xjohnx
Grip>Slip
xjohnx's Avatar
Have you checked DI seals? having one of those go bad could result in a lean condition like @ft_sjo suggested. Granted, I would think you'd see a misfire or coil pack code too, but it's worth a look.
Long Term FR-S regal Scion FR-S / Toyota 86 GT86 General Forum 83 04-01-2016 06:40 AM
long term trd air filter owners...? BlackyRose Engine, Exhaust, Transmission 0 07-12-2013 05:48 PM
Long term Bt216 Scion FR-S / Toyota 86 GT86 General Forum 3 06-06-2013 11:58 PM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
