Old 04-15-2014, 12:00 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Fuel trims abnormal after cleaning intake.
Hello all, I have been beating my head on this for a few weeks now. I do have a tune but I'm seeing the same things on the stock flash as well. Either before the first autox event or right after I decided to take my intake apart(evo intake tube, drop in trd filter) clean it make sure there was no nastiness in the throttle body ect. Put every thing back together and since then I have been having short term trims jump to about plus 20 on idle. Talking with my tuner it leads us to a intake leak someplace.
Before I did this trims and what not were all fine and in place.
So I have re-taken apart and put this thing back together at least 5 times trying to find the spot. Also cleaned and re-oiled the trd filter. Still having issues. Thinking of putting the stock system and paper filter back on and see what happens.
Any help would be great.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 04-15-2014, 12:49 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Checked the MAF sensor itself and given it a clean? All clamps on tight?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-15-2014, 02:12 PM   #3
feldy
feldy's Avatar
Ill check the mas readings tonight. All clamps are tight.
Old 04-15-2014, 09:10 PM   #4
roddy
roddy's Avatar
Drives: '13 Ultramarine
I could be off base here as it's been a while since I had mine apart, but I believe there is a small O-ring where the MAF sensor mounts. Is it possible this is missing or damaged?
Old 04-16-2014, 02:28 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
That was my next shout too.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-16-2014, 12:35 PM   #6
feldy
feldy's Avatar
The maf sensor has never been unbolted from the stock airbox unit. Its still like it was from the factory.
@csgmike did you guys see fuel trim issues when you had the leaky injector?
Old 04-16-2014, 12:49 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
Pull your maf and clean it. I had some issues with filter oil on my maf causing a lean idle and lean tip-in... sounds like the trd filter is oiled?
Do you have drivability issues sich as tip in hesitation?
Throwing the stock intake on to check the trims would be a good first step as well
2013 FRS
Vortech V3 11psi
Old 04-16-2014, 02:55 PM   #8
feldy
feldy's Avatar
Not really any hesitation other then tq dip. I will clean the maf tonight. The trd filter is oiled.
Old 04-16-2014, 04:48 PM   #9
arghx7
Drives: car
What happens if you go to the dealer and get a brand new stock filter and then run a stock flash with it?
arghx7 is offline   Reply With Quote
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Fuel trims video mike_ekim1024 Software Tuning 1 12-20-2013 08:01 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 02:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 09:55 PM
AFE | Takeda| Injen intake sale! Free cleaning kit! Mengsta Engine, Exhaust, Bolt-Ons 0 12-17-2012 02:02 AM
