Drives: 2015 Subaru BRZ
Negative Short term fuel trims at idle w/ no obvi leak
Has anyone encountered a turbo application that resulted in negative short term fuel trims at idle that range from 0% to -20% with no obvious vacuum leak?
FMIC setup with EBC and BOV PCV Valve has been switched to an STI PCV Valve added 9 Clamps to pcv system EcuTek tuning Throwing code P0068. MAP sensor replaced with new Omni 3 Bar. consensus is vacuum leak, but haven't been able to find a leak. What could cause this? Defective equipment? Bad install? Bad tune file? Please don't say it has to be a vacuum leak? ![]() HALP log attached Really stuck on this one. |
Clean your MAF sensor.
Perhaps adding catch cans to your car will help, as could adding a check valve to your manifold to crank case line. |
#3 | |
The shop just said, "Your car isn't running timing" any ideas on that? The STI PCV Valve should be enough to prevent any vacuum issues that the check valve would address, but for a couple dollars I'll gladly install one. Is this a mechanical or tuning issue? Could this have happened after hard pulls for logging? |
#4 | |
Drives: toyota 86
Your advanced multiplier is 0.16 which is very very bad.the ignition will run on a retarded map . it knocks everywhere at medium load. It think the tune is bad . and the MAF scaling is way off . you're not geting enough fuel at medium load, hence the knocks .
Vacuum leak was ruled out by a shop. They uninstalled and reinstalled the kit to check for DIY errors, of which thankfully there were few and none that would cause this.
I'm waiting on a new tune file to verify bad tune. I have a gut feeling it is the tune, but I know part of that is a fear of what else it could be. If it does turn out to be the tune, I'm going to have spent more than I paid for the tune to have it diagnosed and corrected. Not happy and miss my car either way. |
#7 | ||
If there were a few errors on your original DIY install, there can be more that isn't immediately obvious to the shop. have you tried resetting the ECU? I'm still gonna go with you have a leak somewhere. Quote:
Drives: slow
Vacuum leaks are generally followed by positive fuel trims because there is extra air being introduced to the engine that the MAF doesn't know about. Negative fuel trims are more indicative of airflow being less than expected due to clogged air filters, stuck bypass valves etc...
#9 | |
Drives: 86
#10 |
Drives: 86
from ur log
high pressure pump not normal idle goes rich and normal like a waves |
#11 |
Drives: 86
#12 | |
#13 |
Drives: slow
Yeah, a smoke test should be the first thing performed once any forced induction system has been added...
#14 |
Drives: 2013 Scion FRS
Any solution?
| Fuel trims abnormal after cleaning intake. | feldy | Engine, Exhaust, Transmission | 8 | 04-16-2014 04:48 PM |
| Fuel trims video | mike_ekim1024 | Software Tuning | 1 | 12-20-2013 08:01 AM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
