Old 05-11-2015, 08:09 PM   #29
roddy
roddy's Avatar
Drives: '13 Ultramarine
I can pee farther than you can pee...
The Following 3 Users Say Thank You to roddy For This Useful Post:
Beil (05-15-2015), pushrod (08-21-2019), Ryancdossey (07-27-2015)
Old 05-11-2015, 08:16 PM   #30
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
The sludge on the magnet is there because the magnet works as designed. You are incorrect in assuming there is "still more sludge in there."
It's your car. You aren't hurting anything. Have at it.
As mav1178 said there was Still sludge after his first differential change. Yes there will be more after the first - yes it should be less sludge on the magnet than the first.
Originally Posted by mav1178 View Post
It's a supreme waste of money.
By your logic, it would be acceptable to change your oil every 1000 miles since it will just get dirty...
Yes it can work, but it's just a waste of money and resources.
-alex
What you're saying is that it is Impractical not Illogical.
If you want to be Practical and Logical you can just drain the relatively virgin oil after 5k miles into a clean oil pan, clean the drain plug, and refill the differential with the same oil assuming it is just as good - which it should be.
Old 05-11-2015, 08:23 PM   #31
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
No you completely misread what I wrote.
What I'm saying is this: the sludge/shavings will always be there. You change your oil based on the ability of the oil to protect the differential, not based on what sludge is left.
Same thing applies for the transmission, same thing for the engine.
For the average driver you follow the factory service interval.
I never said it was illogical, you said it. What I said is that this is absurd.
Which is fine, just don't use buildup on the drain plug as a measure of how much contaminants are left in the oil. That's just absurd.
If you want to change it sooner, fine. Just don't claim it is better at removing contaminants until you have UOA done.
-alex
Old 05-13-2015, 10:59 PM   #32
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
I change mine every Thanksgiving weekend. Haters be haters but I sleep well when I'm done and knowing that I extendent the life of "my car".
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 05-13-2015, 11:31 PM   #33
That's a great schedule.
Changing it more often is cool. Approaching 13K. Imma change mine next weekend.
Old 05-13-2015, 11:53 PM   #34
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Noob question: would a dealership service dept. be able to know you used non-OEM fluids? I know that can be a reason for warranty invalidation.
Jyn is offline   Reply With Quote
Old 05-14-2015, 12:01 AM   #35
I call BS.
Old 05-14-2015, 12:06 AM   #36
I think it just has to meet manufacturer's specs.
Jyn (05-14-2015)
Old 05-14-2015, 01:09 PM   #37
Cope52
Drives: 2014 BRZ
I don't think u can find it. It only comes in 5 gallon pails which means the dealer would have to do it?
Originally Posted by LeeMaster View Post
I cannot stress this enough, when I changed my rear differential fluid with Motul 300, my clutch engagement point felt smoother.
Cope52 is offline   Reply With Quote
Old 05-14-2015, 01:38 PM   #38
mav1178
mav1178's Avatar
Who cares? If they ask, you show them the oil specs.
As long as it is within the range suggested by the manufacturer, it is not an issue. Any dealer that argues otherwise doesn't deserve your business.
If you used something out of the range... then you're SOL.
-alex
Old 05-14-2015, 09:35 PM   #39
My owner's manual calls for:
LS diff - 1.2 qt Toyota Genuine Differential Gear Oil LX
- other API GL-5 and SAE 75W-(85 or 90)
tranny - 2.3 qt Toyota Genuine MG Gear Oil special II
- other API GL-3 and SAE 75W-90
SPCorBUST (05-17-2015)
Old 05-16-2015, 11:10 PM   #40
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Here's what came out of mine today, 14K miles
and the drain plug was covered in shavings.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Bonburner (05-17-2015)
Old 05-17-2015, 12:26 AM   #41
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
that mushroom marina looks tasty~
The Following User Says Thank You to Bonburner For This Useful Post:
Decay107 (05-17-2015)
Old 05-17-2015, 09:38 AM   #42
BRZnut
Drives: BRZ DGM Limited
just wondering..what is the official recommended change interval from Subaru?
WEIR Performance 4.56 FD & IS300 LSD Rear Differential SportInjected Transmission and Driveline 3 08-09-2014 09:36 AM
FS: Rear Differential with Cusco 4.55 Installed SOLD mrk1 Engine, Exhaust, Bolt-Ons 6 05-28-2013 01:34 PM
Eww rear differential goo LeeMaster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 04-10-2013 09:17 PM
Rear End/Gear/Differential Ratio fly2low Engine, Exhaust, Transmission 9 02-09-2013 11:53 AM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
