Old 04-08-2013, 05:51 PM   #1
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Eww rear differential goo
Did this about three weeks ago, just didnt have time to post it up.
Miles was 4800 when I did the Rear Differential fluid change. There was definitely small metal shavings that was on the magnetic drain plug when I cleaned it out. After I changed to Motul gear 300 the shifting after releasing clutch feels a bit smoother now, not perfect, but better than what it came from the factory that even my wife notice it.
LeeMaster is offline   Reply With Quote
Old 04-08-2013, 06:44 PM   #2
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
I had the same to say about my fluid switch. I'm thinking about trying Pentosin next, since that's garnered a lot of praise. Did you also have bushings and inserts installed?
Anthonytpt is offline   Reply With Quote
Old 04-08-2013, 10:22 PM   #3
LeeMaster
Red wine
No bushings or inserts, everything is still stock minus the fluids.
Old 04-10-2013, 02:32 PM   #4
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
wow, seeing all those shavings makes me want to change mine out asap! did u just drain in fill or did u flush it out then fill?
DAN_BRZ is offline   Reply With Quote
Old 04-10-2013, 02:52 PM   #5
LeeMaster
Red wine
I flushed it then fill.
Old 04-10-2013, 03:03 PM   #6
suaveflooder
Curious as to why you did the fluid swap. You about to start open tracking?
suaveflooder is offline   Reply With Quote
Old 04-10-2013, 03:25 PM   #7
LeeMaster
Red wine
That, and to get rid of the factory oil ASAP. My concept is to change any break-in oil asap. But thats just me you know what i mean..
Old 04-10-2013, 03:51 PM   #8
suaveflooder
Yeah, I get it
Old 04-10-2013, 03:55 PM   #9
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Anything the magnet picks up, it's not going to let go of. Therefore, changing the diff oil early may not have any benefit.
SloS14 is offline   Reply With Quote
Old 04-10-2013, 04:09 PM   #10
DAN_BRZ
DAN_BRZ's Avatar
i disagree, ur diff gears are going to make a lot of turbulence inside the case, and i can see it breaking loose all the fine metal bits, only to have them stick back to the magnet once the car is parked and everything settles back down to the bottom.
Old 04-10-2013, 04:10 PM   #11
DAN_BRZ
DAN_BRZ's Avatar
is the factory drain plug magnet or did u swap it out for something aftermarket?
Old 04-10-2013, 04:59 PM   #12
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
factory diff plug is magnetic.
celica73 is offline   Reply With Quote
Old 04-10-2013, 07:54 PM   #13
SloS14
SloS14's Avatar
Physics will take your disagreement into consideration.
Old 04-10-2013, 09:17 PM   #14
Lonewolf
Lonewolf's Avatar
Drives: Moped
Wow, I'm not used to seeing shavings like that in under 5K miles...it seems that better fluid may be in order...
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Differential growl or ratcheting Roadstercycle Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 09:13 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
