Drives: 2013 Subaru BRZ
Rear Differential Oil Change - How Often?
How often do you guys change your rear differential fluid?
I changed my first one last summer. I am thinking of changing it some time soon, but not sure if it's a time interval or certain mileage I am supposed to do it at? Even my oil changes, I do it every 4 months regardless. |
6/22/12-2/6/24
I waited until 30k but I wish I changed it at 15k or 10k even. There are a lot of stuff on that magnetic .. I plan on changing it out again at 40k.
Drives: '13 Ultramarine
It may or may not be necessary, but I change mine once a year, usually around the holiday weekend in May. I change the transmission fluid (manual) at the same time. That works out to every 25,000kms or so.
@Bonburner...the 1st change always looks kind of scary. You wont see as much on the next changes even if you go as long on the interval. When the gears are new, they need to "take a seat" to each other, and this produces the fine particles that make up the paste that's stuck to the magnet. IIRC, I first changed mine at 1,300 miles or so, and it was already pretty grungy looking. Each change after that has had less and less material on the magnet. My personal preference for differential fluid is Redline's 75W85 high performance GL5 gear oil. I drive the FR-S all year as my daily driver. If it was summer exclusive, or the car saw some track duty, I would consider a 75W90.
6/22/12-2/6/24
My primary concern is if there is That much gunk on the drain plug then how much gunk is still in there - more flushes will extract more gunk lol
6/22/12-2/6/24
The problem is if there is gunk on the drain plug then there is More gunk inside as well - kind of like termites .. Sure you can kill off termites in this one spot but throughout the house there're more
The magnet on the drain plug does a good job of pulling the bad stuff out of the oil.
There's no harm changing out the fluids sooner, I personally believe. It's relatively inexpensive maintenance.
Drives: 2015 Scion FRS
When you change the Differential Oil (or even the Manuel Transmission Oil) do you guys buy new crush washers, or reuse the originals?
#10 | |
Off Topic
http://www.ft86club.com/forums/showp...0&postcount=49 |
#11 |
I wouldn't re-use the ones on the diff, but no problems using the ones on the transmission a couple of times.
#12 |
^Yeah, the washers are cheap. I bought a few at my local dealership, came out to $1.50 each.
#13 | |
Drives: Raven
Changed Diff fluid at 13,300 miles (21,404 km). Oh and just remember there is no space above the fill plug, none! Bottles can be positioned only horizontally. I had to squeeze the hell out of 2 Motul bottles to get it to fill. And finally realized there is an inverted nipple in each bottle that can pulled out for better filling. Torque setting is higher for the Diff Plugs, so I used new crush washers.
something smelly, and you still have crickets.. |
#14 | |
not playing cards
The only reason to change the gear oil would be out of concern for viscosity breakdown, not pest control.
| WEIR Performance 4.56 FD & IS300 LSD Rear Differential | SportInjected | Transmission and Driveline | 3 | 08-09-2014 09:36 AM |
| FS: Rear Differential with Cusco 4.55 Installed SOLD | mrk1 | Engine, Exhaust, Bolt-Ons | 6 | 05-28-2013 01:34 PM |
| Eww rear differential goo | LeeMaster | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 04-10-2013 09:17 PM |
| Rear End/Gear/Differential Ratio | fly2low | Engine, Exhaust, Transmission | 9 | 02-09-2013 11:53 AM |
| Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
