#57 |
Drives: frs
All I can comment on is my experience. I have nothing but flawless shifting wit MT-90. It hasn't made the little grind sound at all since I put it in. It's been in nearly one year now.
#58 |
Drives: Frs asphalt Grey
That's aswome bro well I'm going to switch becuase I belive it's the oil not the transmission especially after I changed it it started and before it didn't thank bro
#59 |
Drives: Subaru impreza STI, subaru BRZ
Well this last week mine started doing the same thing, crunch from 3rd to 4th over 6.5k rpms. 2014 brz with 13k miles.
#60 |
#61 |
My transmission has always been smooth, but this i noticed a couple of days ago and it really irritated me. Brand new car and transmission is messed up. I am going to try to go to subaru to see what they say.
#62 |
They will replace it but it will come back from what I heard even if you baby it
#63 |
#64 |
True as long as there isn't any negative equity I would do it or wait till fa20 sti
| The Following User Says Thank You to Albaro08 For This Useful Post: | jester04 (05-13-2015) |
#65 |
My 2006 sti is paid for and i should amost break even on the brz. We shall see man, i had really high hopes for this car. The steering and handling is excellent transmission leaves a lot to be desired.
#66 |
Drives: 00 Accord LX, 14 FRS
This is really disappointing. My '14 FRS w/ ~11k miles on it has started this "grind"/"crunch" on 3-4th gear shifts and even 5th-4th gear rev matched down shifts. This sucks b/c my dealership sucks and I'm gonna have to convince them of this issue again. It was a major pia to convince them to replace the fuel pump and now this. Frustrating.
How long does transmission replacement work take? couple of days? |
#67 |
Drives: '13 BRZ
Bought my car used at 26k miles, started getting grind from 3rd to 4th when shifting over 4k RPM, worse with higher RPM. Covered under warranty with a new transmission. Trans was ordered Saturday, dropped my car off Monday, picked it up Wednesday. They were not backordered at the time, but the service rep said the transmissions are frequently on backorder.
Once they have the transmission, it should take them two days. |
| The Following User Says Thank You to BRZoomTX For This Useful Post: | dentalprodigy (08-28-2015) |
#68 |
Drives: 2014 FR-S 6MT Whiteout
My dealer insists this is totally normal. I honestly don't think they even tested it. One of these days I'll get them to do a ride along.
| The Following User Says Thank You to phobos512 For This Useful Post: | dentalprodigy (08-28-2015) |
#69 |
Phobos512 that stinks; I hope my dealership doesn't take the same position. It's NOT normal because it wasn't happening during the 10k miles that I drove it. Perhaps try different dealership in your area??
Ron Good to know it takes only couple of days if part is in stock. Just to document the issue during the test drive, I'll keep my dashcam turned on. |
#70 | |
Drives: '13 BRZ
Not sure how bad yours is, but mine made a very audible grinding sound when shifting to 4th. |
| Motul gear 300 or Redline MT90? | BRZ NA | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 70 | 11-30-2016 03:02 PM |
| Steering grind | Kregar | Issues | Warranty | Recalls / TSB | 19 | 08-11-2014 02:47 PM |
| redline | kendalldwhite | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 08-26-2012 02:12 PM |
| 3rd gear grind | Mo707 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 07-29-2012 07:37 PM |
| Fr-s vs. Saturn Sky Redline - would your rather | Gabriel | FR-S / BRZ vs.... | 7 | 06-07-2012 12:57 AM |
