Old 05-12-2015, 06:10 PM   #57
twag4
Drives: frs
Originally Posted by Albaro08 View Post
Is it still good with redline my grinding started after the change never had it before that in any gear so you can be right
All I can comment on is my experience. I have nothing but flawless shifting wit MT-90. It hasn't made the little grind sound at all since I put it in. It's been in nearly one year now.
twag4 is offline   Reply With Quote
Old 05-12-2015, 06:12 PM   #58
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
Originally Posted by twag4 View Post
All I can comment on is my experience. I have nothing but flawless shifting wit MT-90. It hast made the little grind sound at all since I put it in. It's been in nearly one year now.
That's aswome bro well I'm going to switch becuase I belive it's the oil not the transmission especially after I changed it it started and before it didn't thank bro
Albaro08 is offline   Reply With Quote
Old 05-13-2015, 12:26 AM   #59
jester04
Drives: Subaru impreza STI, subaru BRZ
Well this last week mine started doing the same thing, crunch from 3rd to 4th over 6.5k rpms. 2014 brz with 13k miles.
jester04 is offline   Reply With Quote
Old 05-13-2015, 05:16 AM   #60
Albaro08
Albaro08's Avatar
Sucks bro mines started after the change but before it was just not buttery smooth now it is but with the grind
Old 05-13-2015, 07:34 AM   #61
jester04
My transmission has always been smooth, but this i noticed a couple of days ago and it really irritated me. Brand new car and transmission is messed up. I am going to try to go to subaru to see what they say.
Old 05-13-2015, 07:46 AM   #62
Albaro08
Albaro08's Avatar
They will replace it but it will come back from what I heard even if you baby it
Old 05-13-2015, 01:15 PM   #63
jester04
Don't think i could live with that, might just sell my sti and my brz and get a brand new sti and call it a day.
Old 05-13-2015, 01:38 PM   #64
Albaro08
Albaro08's Avatar
True as long as there isn't any negative equity I would do it or wait till fa20 sti
Old 05-13-2015, 06:12 PM   #65
jester04
My 2006 sti is paid for and i should amost break even on the brz. We shall see man, i had really high hopes for this car. The steering and handling is excellent transmission leaves a lot to be desired.
Old 08-25-2015, 11:44 PM   #66
dentalprodigy
dentalprodigy's Avatar
Drives: 00 Accord LX, 14 FRS
This is really disappointing. My '14 FRS w/ ~11k miles on it has started this "grind"/"crunch" on 3-4th gear shifts and even 5th-4th gear rev matched down shifts. This sucks b/c my dealership sucks and I'm gonna have to convince them of this issue again. It was a major pia to convince them to replace the fuel pump and now this. Frustrating.
How long does transmission replacement work take? couple of days?
dentalprodigy is offline   Reply With Quote
Old 08-27-2015, 12:13 PM   #67
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Bought my car used at 26k miles, started getting grind from 3rd to 4th when shifting over 4k RPM, worse with higher RPM. Covered under warranty with a new transmission. Trans was ordered Saturday, dropped my car off Monday, picked it up Wednesday. They were not backordered at the time, but the service rep said the transmissions are frequently on backorder.
Once they have the transmission, it should take them two days.
BRZoomTX is offline   Reply With Quote
Old 08-27-2015, 09:46 PM   #68
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
My dealer insists this is totally normal. I honestly don't think they even tested it. One of these days I'll get them to do a ride along.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 08-28-2015, 07:17 AM   #69
dentalprodigy
Phobos512 that stinks; I hope my dealership doesn't take the same position. It's NOT normal because it wasn't happening during the 10k miles that I drove it. Perhaps try different dealership in your area??
Ron Good to know it takes only couple of days if part is in stock.
Just to document the issue during the test drive, I'll keep my dashcam turned on.
Old 08-28-2015, 10:01 AM   #70
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Contact corporate, look for service reps on Subaru forums and find a higher-up contact. The issue is 100% not normal. The grind is from the 4th gear syncro failing and not being able to properly match trans speed when shifting during higher RPM.
Not sure how bad yours is, but mine made a very audible grinding sound when shifting to 4th.
Motul gear 300 or Redline MT90? BRZ NA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 70 11-30-2016 03:02 PM
Steering grind Kregar Issues | Warranty | Recalls / TSB 19 08-11-2014 02:47 PM
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 02:12 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
Fr-s vs. Saturn Sky Redline - would your rather Gabriel FR-S / BRZ vs.... 7 06-07-2012 12:57 AM
