View Poll Results: Motul gear 300 or Redline MT90 for transmission & Differential?
Motul gear 300 193 71.75%
Redline MT90 76 28.25%
Voters: 269. You may not vote on this poll
Old 11-07-2012, 12:50 AM   #1
BRZ NA
Drives: WR blue
Motul gear 300 or Redline MT90?
I m trying to choose which one is better to use for transmission and differential.Motul or Redline?need some feedback from people who used them please.and this is my first time changing those fluid myself so just to confirm,there is no additive need to be added in right?and also,is the crush washer same size as the oil pan one?thx
BRZ NA is offline   Reply With Quote
Old 11-07-2012, 01:37 AM   #2
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Definitely would avoid the Motul 300 for the trans(we aren't GL-5 rated), but it should be excellent in the diff(what I'm using). Make sure you just get the standard gear lube version though as we don't need the friction modifiers found in the LS version as we don't have a clutch diff.
For the trans I would(and I am) run Amsoil MTG. Proper GL-4 rated fluid that won't eat our syncros unlike what the dealer tried to sell me for a change. I tend to have a rather negative view of Redline as I feel they focus more on hitting the buzzwords than actually delivering a product.
Read around, check bobtheoilguy.com, and get informed. I suspect you will come to similar conclusions.
You also need to order all this crush washers/gaskets(the tranny uses two of the same):
2x M/T Fill plug gasket: 17008AA050
Rear Diff Fill plug gasket: 11126JB000
Rear Diff Drain plug gasket: 1215710010
3.2 911 5MT
BRZ Limited 6MT
BMW E82 128i 6MT
BMW E39 M5 6MT
BMW E36 M3 5MT
TheSt|G is offline   Reply With Quote
Old 11-07-2012, 07:51 AM   #3
M1K3
M1K3's Avatar
Drives: vrooom...
Yes I like:
M1K3 is offline   Reply With Quote
Old 11-07-2012, 08:24 AM   #4
TheSt|G
TheSt|G's Avatar
Originally Posted by M1K3 View Post
Yes I like:
Yup, very good stuff with a long and established record.
3.2 911 5MT
BRZ Limited 6MT
BMW E82 128i 6MT
BMW E39 M5 6MT
BMW E36 M3 5MT
Old 11-07-2012, 09:02 AM   #5
gmookher
http://www.ft86club.com/forums/showt...t=16604&page=7
gmookher is offline   Reply With Quote
Old 11-07-2012, 09:48 PM   #6
BRZ NA
Drives: WR blue
Originally Posted by gmookher View Post
thx,alot of reading.
Old 11-07-2012, 09:50 PM   #7
BRZ NA
Drives: WR blue
looks like most people would recommend use redline MT-90 for transmission and motul 300 for diff?
Old 11-07-2012, 09:56 PM   #8
White Shadow
Drives: 12,000 miles per year
Did you look into Redline MTL? I'm not sure if it's the correct oil for the gearbox on these cars or not, but if it is compatible, I'd highly recommend it, as it made a fantastic difference in cold weather shifting in some of my past cars.
White Shadow is offline   Reply With Quote
Old 11-07-2012, 10:17 PM   #9
bluesubie
+1! Like any forum though, you just need to filter out the noise.
Synchromesh Manual Transmission Lubricants.
Most GL5 differential and GL4 Manual Transmission oils contain sulfur-phosphorous EP packages. GL4 does NOT refer to any specific viscosity, but it refers to a level of AW/EP protection for the gearing and bearings in a transmission. GL4-rated oils contain about 40% to 60% of the EP additives that GL5 oils contain.
Gear Tribology and Lubrication
GL-4; Specified for hypoid gear service under severe service but without shock loading. This classification is essentially obsolete but is still specified by some manual transmission/transaxle manufacturers. Implies an EP/AW additive package that contains 30% to 50% less S-P additives than the GL-5 service classification. Some Marine Gear Lubes fall into this classification, especially the full Synthetic Marine Gear lubes and specialty blenders MT lubes that use high levels of esters.
GL-5; Specified for hypoid gear service but with shock loads and severe service operation. Usually meets Mil-L-2105D and in most cases, is the multipurpose automotive gear oil. Most 75W90 to 75W140 grades meet the GL-5 classification. This grade has a high level of Extreme-Pressure additives that could be mildly corrosive to nonferrous parts, such as brass, bronze and aluminum parts. Most of the modern GL-5 lubes contain metal deactivators that prevents attacks by the extreme-pressure additives. In addition to EP additives, these lubes contain rust inhibitors, defoamants, friction modifiers, thickeners, and Viscosity Index Improvers.
I'm guessing that Motul claims Gear 300 meets both GL4 and GL5 because it may contain metal deactivators. I do not blend their gear oil, so maybe it would be best to ask Motul how they meet both specs. Or maybe Molakule at bitog can shed some light on this. He has blended gear oil and highly recommends Gear 300 for Subaru differentials.
-Dennis
bluesubie is offline   Reply With Quote
Old 11-08-2012, 06:41 AM   #10
philstar
philstar's Avatar
Drives: Argento FR-S
is there a specified amount that goes into the transmission and differential, or just fill until it starts coming out of the fill hole for each?
philstar is offline   Reply With Quote
Old 11-08-2012, 07:40 AM   #11
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
It is a GL4/GL5 and it works great in the transmission. Some of the thinner oils might shift a bit better cold, but once the transmission comes up to operating temperature it gives you nice solid smooth shifts.
http://www.motul.com/system/product_...pdf?1303320907
We have serviced a lot cars locally and have not needed to replace the washers. It couldn't hurt to have them, but it really wasn't necessary, so don't pull your hair out running around to get them if you don't want to.
No Limit Motorsport is offline   Reply With Quote
Old 11-08-2012, 07:43 AM   #12
No Limit Motorsport
There is a spec in the book, something like 2.2 liters for transmission and 1.3 for differential. That being said once you get to the fill spec, the oil starts to come out of the filler hole so you know you are done.
Old 11-09-2012, 10:59 PM   #13
BRZ NA
Drives: WR blue
so any complain about using motul for the trans from your customers?
Old 11-09-2012, 11:07 PM   #14
No Limit Motorsport
Only positives so far. The only thing I can say is that since it is a 75w90 you can notice the transmission shift smoother once it comes up to temp. That being said even cold it is better than the factory. Once up to temp I have no doubt it is offering excellent protection to the transmission internals.
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 02:12 PM
Reaching redline. erom Engine, Exhaust, Transmission 27 07-23-2012 06:46 PM
Fr-s vs. Saturn Sky Redline - would your rather Gabriel FR-S / BRZ vs.... 7 06-07-2012 12:57 AM
Engine 7500rpm redline KiingDavid Engine, Exhaust, Transmission 20 03-13-2011 07:04 PM
