Drives: 13 BRZ, 07 WRX
What is needed for a proper alignment after lowering 1in? LCA's, Camber bolts?
There is a lot of information on this forum but no real answer on what is needed to get a proper or close to stock alignment after lowering the car with lowering springs. I'm ordering swift springs and wondering what else I need. Thanks
13 BRZ Premium. 07 WRX.
#2 |
What do you call a proper alignment?
If you want it back to stock specs, you'll need adjustable arms in the rear (stock toe arms should be fine). If you want something better suited to spirited driving you'll need adjustable arms in the rear and either camber bolts or camber plates up front. With just the springs, you'll probably have around -0.5F and -2R, it'll handle better with -1 to -1.5F and -1R.
#3 |
I'm not a professional but I doubt the alignment will be that far off with a 1 inch drop. You're probably fine without any additional parts. You have no way to adjust camber but whatever it rests at after the drop won't eat your tires or anything, just won't quite be "stock" anymore
#4 |
Drives: Fast
I aim for -1.5 rear and -2 front with coilovers that are slotted. It's hard to get -2 up front otherwise with camber bolts and stock suspension without camber plates. The rear gains a ton of camber as you lower. 0 toe up front, 1/16" toe in on rear. This is pretty good for the street setup and I have no abnormal wear on my tires.
I'm lowered about 1.4" as well. |
#5 | |
I've got -2* all around, fronts needed camber bolts and slotted struts, rears were just there naturally on Swift Sport springs.
#6 | |
Drives: 2015 Fire
May I ask what you mean by slotted struts |
#7 |
They have slots in the top plate so you can adjust camber(front only)
And IMO -2 camber isn't THAT bad. Definitely livable |
#8 |
#9 | |
I would shoot for -2 to -2.5 up front if you have -2 in the rear.
#10 |
I dunno if super understeery is the way I'd look at it. More like slightly more understeery. I'm gonna guys side he is just now lowering he isn't Mario Andretti so I doubt he will notice anything
So OP these are opinions but what you should be getting out of this is, if you want "like stock" alignment, you need adjustable rear control arms. If don't want to spend any more past an alignment, you're probably fine. If you race or notice odd tire wear you'll need those LCAs |
#11 |
Mine is slightly understeery with -2* all around, with -2 in the rear and close to 0 up front it would be very noticeable in spirited driving.
#12 |
I did the S.Tech springs and I ended up with about -2.6 in the rear. The springs are 1" drop in the rear 1.3" front. I put in the H&R Camber bolt in the rear and they were able to dial it down to -2.3. I have the SPC bolts in the front and only got it to -1.5 (if my memory serves me right) in the front.
I was originally thinking something like -2 in the front and -1 in the rear. Since its just DD (spirited driving) I don't feel like going camber plates and LCA (pricey) so I will probably just go LCA and run the -1.5 F and somewhere around 0 to -.5 R.
#13 |
Then don't get the Stance LCA. Nothing wrong with it, but it has a bend in it to automatically drop you. With springs you won't be able to level out. FYI
#14 |
will the -2 camber affect the wear on your tires by a lot?
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| rear camber adjuster bolts or lower control arms needed? | Raven23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 10-31-2013 01:30 AM |
| Front Camber Bolts / Alignment Question | hanabie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-17-2013 04:31 AM |
| Proper Alignment - Post Eibach Pro Lowering | Thatruth2001 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-10-2012 01:48 AM |
| Alignment needed after lowering car? | Lowellrenzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-16-2012 02:57 PM |
