Old 10-14-2013, 06:24 AM   #1
Raven23
rear camber adjuster bolts or lower control arms needed?
I'm planning on going staggered setup 18x8.5/9.5 setup with either eibach pro or sportline spring kit. I've read a lot of people buying rear LCA along with their drop set up.
My question is this necessary when lowering your car a 1" or 1.5"? Basically I want to know what else will I need for a smooth ride when I drop my car besides buying lowering springs. I will not be tracking at all, just my casual DD, going for looks / stance. Thanks!
Raven23 is offline   Reply With Quote
Old 10-14-2013, 06:42 AM   #2
FR-S Matt
If you want the camber and toe to be in spec, yes. The camber goes almost or a bit more than -2 degrees when going 1.5" on the drop. I got the SPC LCA's to go with my Tarmac 0's. Perfect fit, stock feel and adjustable. Love them. I'm at around -1 and -1.3 in the rear now and my car is mostly a daily driver.
Old 10-14-2013, 09:33 AM   #3
bfrank1972
Drives: 2013 FR-S Argento
Depends on what you want -as Matt mentioned, if you want to be factory spec, you'll need some sort of rear camber adjustability with 1.5". FYI threads on this forum have shown the Proline springs drop around 1", or just shy of that, and the Sportline springs drop around 1.2" (they advertise 1.4"). Sportline springs will probably put you around -2 degrees of camber. If you want to be 'stanced', you may want at least that if not more, depending on the look you're going for. If you want performance, you'll probably want to be a little under -2 for the rears. Also you want camber adjustment in the front, so think about oem or aftermarket front camber bolts.
bfrank1972 is offline   Reply With Quote
Old 10-14-2013, 09:44 AM   #4
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
if you have an extra 400$ get the arms, if not you wont die but you will have extra camber for street use. im at 2 deg in the rear but i track it
IG-Joey_Soul
Old 10-14-2013, 10:14 AM   #5
ML
ML's Avatar
Drives: 13 White MT FR-S
I'm dropped 1" and have the camber bolts maxed out front and rear. I might need to dial the rear back a little actually. They are a pain in the ass to install compared to LCAs, but a lot cheaper, and get you a good usable camber.
Old 10-14-2013, 10:26 AM   #6
bfrank1972
@ML, you using those H&R camber bolts in the rear?
Old 10-14-2013, 10:37 AM   #7
ML
ML's Avatar
No, I have these http://www.rallysportdirect.com/Whit...tment-Bushings
Old 10-14-2013, 01:35 PM   #8
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I would get the spc arms. Easy adjustment, and pretty cheap. Great bang for buck item. I'm lowered by over 2" and with SPC arms, I was able to get my camber down to -1.3 and only reason I couldn't go lower is cause the stock toe link is maxed on adjustment.
With new toe links, I could easily get to under -1 for camber
TylerLieberman is offline   Reply With Quote
Old 10-14-2013, 04:42 PM   #9
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Agree SPC arms are the easiest install and very affordable, plus offer a nice range of adjustment. http://ft86speedfactory.com/spc-rear...e-kit-891.html
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-14-2013, 07:27 PM   #10
Raven23
I was leaning towards sportline springs. What negative impact will -2 degrees of camber present to me for daily street driving?
Old 10-14-2013, 09:27 PM   #11
bfrank1972
Shouldn't be a big deal, maybe slightly more wear on the inside vs outside, but probably not a huge deal, just make sure to get it aligned, your toe will change and that *will* affect your tire wear.
Old 10-28-2013, 04:14 AM   #12
Hawk77FT
Drives: GTS 86
Would SPC eliminate the camber?
Hawk77FT is offline   Reply With Quote
Old 10-28-2013, 06:31 AM   #13
FR-S Matt
You will want the SPC LCA's for a daily driver if you want your toe to be back at 0. Otherwise, it will eat your tires. The camber is not so big of a deal. It's the toe that is the the problem. The SPC LCA's allow both to be adjusted. I'm at -0.9 and -1.3 in the back, 0 toe with these LCA's.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Hawk77FT (10-30-2013)
Old 10-30-2013, 01:41 AM   #14
Hawk77FT
Drives: GTS 86
Originally Posted by ML View Post
They look good but it looks like a PITA to have them installed.
rear camber adjuster bolts or lower control arms? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-30-2015 08:34 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
ISC Rear Lower Control Arms FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-26-2013 09:47 AM
SPC Lower control camber arms so cheap? SliverBrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-17-2013 08:33 PM
SPC rear lower control arms, Fix your camber! JoeBoxer Brakes, Suspension, Chassis 12 03-31-2013 07:02 PM
