| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 |
Drives: '13 Ultramarine
I can pee farther than you can pee...
| The Following 3 Users Say Thank You to roddy For This Useful Post: |
#30 | ||
6/22/12-2/6/24
If you want to be Practical and Logical you can just drain the relatively virgin oil after 5k miles into a clean oil pan, clean the drain plug, and refill the differential with the same oil assuming it is just as good - which it should be.
#31 | ||
Drives: 2005 Toyota Camry
What I'm saying is this: the sludge/shavings will always be there. You change your oil based on the ability of the oil to protect the differential, not based on what sludge is left. Same thing applies for the transmission, same thing for the engine. For the average driver you follow the factory service interval. I never said it was illogical, you said it. What I said is that this is absurd. Quote:
-alex |
#32 |
Drives: 2013 BRZ Premium Dark Gray Metallic
I change mine every Thanksgiving weekend. Haters be haters but I sleep well when I'm done and knowing that I extendent the life of "my car".
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#33 |
That's a great schedule.
Changing it more often is cool. Approaching 13K. Imma change mine next weekend.
#34 |
Noob
Drives: FR-S Mammogram
Noob question: would a dealership service dept. be able to know you used non-OEM fluids? I know that can be a reason for warranty invalidation.
#35 |
#36 |
I think it just has to meet manufacturer's specs.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Jyn (05-14-2015) |
#37 |
Drives: 2014 BRZ
I don't think u can find it. It only comes in 5 gallon pails which means the dealer would have to do it?
#38 | |
As long as it is within the range suggested by the manufacturer, it is not an issue. Any dealer that argues otherwise doesn't deserve your business. If you used something out of the range... then you're SOL. -alex |
#39 |
My owner's manual calls for:
LS diff - 1.2 qt Toyota Genuine Differential Gear Oil LX - other API GL-5 and SAE 75W-(85 or 90) tranny - 2.3 qt Toyota Genuine MG Gear Oil special II - other API GL-3 and SAE 75W-90
| The Following User Says Thank You to Ultramaroon For This Useful Post: | SPCorBUST (05-17-2015) |
#40 |
Turning is for Nerds
Drives: 35 characters is not enough
Here's what came out of mine today, 14K miles
![]() and the drain plug was covered in shavings.
| The Following User Says Thank You to Decay107 For This Useful Post: | Bonburner (05-17-2015) |
#41 |
6/22/12-2/6/24
that mushroom marina looks tasty~
| The Following User Says Thank You to Bonburner For This Useful Post: | Decay107 (05-17-2015) |
#42 |
Drives: BRZ DGM Limited
just wondering..what is the official recommended change interval from Subaru?
| WEIR Performance 4.56 FD & IS300 LSD Rear Differential | SportInjected | Transmission and Driveline | 3 | 08-09-2014 09:36 AM |
| FS: Rear Differential with Cusco 4.55 Installed SOLD | mrk1 | Engine, Exhaust, Bolt-Ons | 6 | 05-28-2013 01:34 PM |
| Eww rear differential goo | LeeMaster | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 04-10-2013 09:17 PM |
| Rear End/Gear/Differential Ratio | fly2low | Engine, Exhaust, Transmission | 9 | 02-09-2013 11:53 AM |
| Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
