| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2013 BRZ Limited White
Glad to know I'm not the only one. Switched to E85 a few weeks ago and lately I've been noticing the same thing. It kind of sputters and sounds like it's going to stall, and then recovers.
#16 | |
Drives: FT86
The Higher you E% the earlier you will start to get start hesitations. either tweak the Cranking Injector pulse widths or add a bit of petrol to your E85. See above posts. or you can do both if its really cold. I start to notice it at about 55F but our E85 is about E90 constant another alternative http://www.ft86club.com/forums/showt...21#post1444921 |
#17 | |
Drives: Panda FR-S
I feel bad for the rest of socal especially OC. lol
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
| The Following User Says Thank You to Cal3000 For This Useful Post: | SirBrass (05-07-2015) |
#18 | |
Road-hole
Drives: 2013 Whiteout FR-S
yeah but I try not to fill up there...
Or beaumont where I get it for 2.29... It's 2.85 on Murrieta Hot Springs right now... Jaden |
#19 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
No issues cold starting with my Flex Fuel kit and FF tune. I had issues before with a regular E85 tune via EcuTek.
OFT cant do flex fuel though. |
#20 |
Drives: point A to point C. Screw point B!
I have the modified cranking tables set on my OFT tune. Cranks first time on 40 or 50 degree days, but I found if I blip the throttle right after starting, I get less hesitation. Goes away completely after 15-20 seconds. No issues on warmer starts.
#21 |
#22 | |
#23 | |
OFT E85 tunes are canned tunes which do not adjust on the fly based on the actual ethanol content which in a true flex fuel setup is measured from a sensor in the fuel lines. FlexFuel requires a fuel line kit and sensor with an output to the ECU which the tune uses to adjust timing/AFR in real time based on the actual E content. OFT cant do this. EcuTek can. ![]() ![]() True flex fuel is safer and more convenient since actual ethanol content from E85 pumps can vary greatly by season. From 60-70% in the winter to 80-85% in the summer. With flex fuel you can run whatever mixture of pump gas and E85 that you want without having to run the tank dry before switching fuels. The tune is always spot on as the timing and AFR targets are referenced by a custom map that's based on the signal from the ethanol content analyzer. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | MikeM7 (05-08-2015) |
#24 |
Ok, thanks for the clarification. I just thought they were the same thing because the E85 pump says "for flexfuel vehicles only" on it.
So.. is there any reason to be concerned since I'm running OFT E85 UEL tune and filling up with only E85? |
#25 | |
Drives: FT86
http://www.ft86club.com/forums/showthread.php?t=53477 |
| Afe Pro Dry S air filter users | tracerit | Engine, Exhaust, Transmission | 9 | 07-17-2015 11:33 AM |
| Why have so many users been banned? | xuimod | Site Announcements / Questions / Issues | 9 | 03-08-2015 02:23 PM |
| Firefox users | V_86 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 01-03-2015 07:42 PM |
| E-85 users thread | Crossover Auto | Engine, Exhaust, Transmission | 41 | 11-16-2012 07:21 PM |
| Rwd toyota users here? | aphxero | Other Vehicles & General Automotive Discussions | 14 | 12-23-2009 09:34 PM |
