Old 05-01-2015, 10:50 PM   #15
MikeM7
Drives: 2013 BRZ Limited White
Glad to know I'm not the only one. Switched to E85 a few weeks ago and lately I've been noticing the same thing. It kind of sputters and sounds like it's going to stall, and then recovers.
MikeM7 is offline   Reply With Quote
Old 05-01-2015, 10:52 PM   #16
steve99
Drives: FT86
Originally Posted by FloridaBRZ View Post
Any one else running E85 with an OFT Stg2 UEL tune? I have found that since running E85, I have had a slower than normal start first thing in the morning. Just the very first start, it seems to hesitate a bit. Unfortunately, it seems to be getting worse. This morning I started my car and it hesitated for a second, then seemed like it almost stalled. I drive a manual, if it makes a difference. I didn't know if the viscosity of E85 was different than normal 93 octane, and it was just a fuel pump issue and nothing to worry about, or if I should go back to 93 octane. I don't want to damage my car.
Thanks,
Tim
Depending on your E% you may get cold start issues once temps get below about 50F
The Higher you E% the earlier you will start to get start hesitations.
either tweak the Cranking Injector pulse widths or add a bit of petrol to your E85. See above posts. or you can do both if its really cold.
I start to notice it at about 55F but our E85 is about E90 constant
another alternative
http://www.ft86club.com/forums/showt...21#post1444921
Old 05-01-2015, 11:17 PM   #17
Cal3000
Drives: Panda FR-S
Originally Posted by Jaden View Post
I live in southern california and it's the same thing. Don't worry about it. I hate having to turn it over twice so I'll feather the gas pedal and it won't stall out...
Jaden
You live in Temecula. You have a E85 station on Murrieta Hot Springs and another 5 miles down on Clinton Keith. lol
I feel bad for the rest of socal especially OC. lol
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
SirBrass (05-07-2015)
Old 05-02-2015, 01:14 PM   #18
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
yeah but I try not to fill up there...
I work in Mo Valley and I drive over to calimesa where I get E85 for 2.19 a gallon...
Or beaumont where I get it for 2.29... It's 2.85 on Murrieta Hot Springs right now...
Jaden
Jaden is offline   Reply With Quote
Old 05-07-2015, 11:18 AM   #19
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
No issues cold starting with my Flex Fuel kit and FF tune. I had issues before with a regular E85 tune via EcuTek.
OFT cant do flex fuel though.
Old 05-07-2015, 12:55 PM   #20
rlpaul
Drives: point A to point C. Screw point B!
I have the modified cranking tables set on my OFT tune. Cranks first time on 40 or 50 degree days, but I found if I blip the throttle right after starting, I get less hesitation. Goes away completely after 15-20 seconds. No issues on warmer starts.
rlpaul is offline   Reply With Quote
Old 05-07-2015, 02:36 PM   #21
MikeM7
Then why can you download E85 tunes from their website? A lot of people run E85 with OFT tune and nothing else.. and E85 = flex fuel right?
Old 05-07-2015, 02:49 PM   #22
rlpaul
What @ATL BRZ is saying is OFT doesn't accept input from Flex Fuel sensors. With a Flex Fuel tune and sensors, you can run anything from 91 octane gas to E90 on the same tune. With the OFT E85 tune, you can run E60 up, but nothing below, and not regular gas.
The Following 3 Users Say Thank You to rlpaul For This Useful Post:
ATL BRZ (05-07-2015), Koa (05-07-2015), MikeM7 (05-08-2015)
Old 05-07-2015, 03:47 PM   #23
ATL BRZ
ATL BRZ's Avatar
E85 tune =/= Flex Fuel
OFT E85 tunes are canned tunes which do not adjust on the fly based on the actual ethanol content which in a true flex fuel setup is measured from a sensor in the fuel lines.
FlexFuel requires a fuel line kit and sensor with an output to the ECU which the tune uses to adjust timing/AFR in real time based on the actual E content. OFT cant do this. EcuTek can.
True flex fuel is safer and more convenient since actual ethanol content from E85 pumps can vary greatly by season. From 60-70% in the winter to 80-85% in the summer. With flex fuel you can run whatever mixture of pump gas and E85 that you want without having to run the tank dry before switching fuels. The tune is always spot on as the timing and AFR targets are referenced by a custom map that's based on the signal from the ethanol content analyzer.
The Following User Says Thank You to ATL BRZ For This Useful Post:
MikeM7 (05-08-2015)
Old 05-08-2015, 10:38 AM   #24
MikeM7
Ok, thanks for the clarification. I just thought they were the same thing because the E85 pump says "for flexfuel vehicles only" on it.
So.. is there any reason to be concerned since I'm running OFT E85 UEL tune and filling up with only E85?
Old 05-08-2015, 10:51 AM   #25
steve99
Drives: FT86
no not if your NA we have enough octane rating at about E60 , boosted is a different story though.
http://www.ft86club.com/forums/showthread.php?t=53477
Afe Pro Dry S air filter users tracerit Engine, Exhaust, Transmission 9 07-17-2015 11:33 AM
Why have so many users been banned? xuimod Site Announcements / Questions / Issues 9 03-08-2015 02:23 PM
Firefox users V_86 Off-Topic Lounge [WARNING: NO POLITICS] 0 01-03-2015 07:42 PM
E-85 users thread Crossover Auto Engine, Exhaust, Transmission 41 11-16-2012 07:21 PM
Rwd toyota users here? aphxero Other Vehicles & General Automotive Discussions 14 12-23-2009 09:34 PM
