| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru BRZ Limited 6sp DGM
E85 Users...I have a question.
Any one else running E85 with an OFT Stg2 UEL tune? I have found that since running E85, I have had a slower than normal start first thing in the morning. Just the very first start, it seems to hesitate a bit. Unfortunately, it seems to be getting worse. This morning I started my car and it hesitated for a second, then seemed like it almost stalled. I drive a manual, if it makes a difference. I didn't know if the viscosity of E85 was different than normal 93 octane, and it was just a fuel pump issue and nothing to worry about, or if I should go back to 93 octane. I don't want to damage my car.
Thanks, Tim |
Drives: Raven Black
e85 doesn't like cold temps during start up. this is normal
That's assuming that its cold in Venice. It's 80 right now in Miami.
I heard once the temp drops below 50F, its a bit more difficult to start because the fuel doesn't vaporize the same. Could be wrong though..
I have also heard cold start is hard, hence the 70% switch in the winter
Okay. As long as Im not damaging anything. That was my primary concern. And its only the first start of the morning, once its sat all night. And Venice is not cold. I believe it was a frigid 75 when I woke up. But if its normal, Im happy. I LOVE the gains that I have and the smooth powerband that E85 has given me. Only problem is driving to get it....only one station with E85 in a 40 mile radius from my house.....
#7 | |
Road-hole
Drives: 2013 Whiteout FR-S
I live in socal...
Jaden |
Senior Misanthrope
I've found that if you turn the ignition on for a few seconds (don't crank the motor, just set the ignition "on") it seems to start up with less hesitation.
Note: this may be all in my imagination. |
Drives: FR-S 10 Series MT, Honda 919
That's priming the fuel pump; any car usually will start easier or the same. It's a safe thing to do that can alleviate component stress.
#10 |
Drives: 2013 FR-S, HKS V2 S/C
Stations are transitioning out of winter blends and into summer blends with higher ethanol contents so it would make sense for it to be a little harder to start on a "cooler" morning. As the weather continues to warm up it should get better for you. Unless you were tuned on E70...
#11 | |
#12 |
Senior Misanthrope
#13 |
Now w/ over 400 womprats!
Drives: BRZ LZR
There's a thread here for modifying the injector pulsewidth for cold starts in RomRaider. My car never had an issue with starting after that. Lemme see if I can find it...
Edit: Found it! http://www.ft86club.com/forums/showp...1&postcount=40 It might take some fine tuning to get it perfect but this post is definitely very helpful.
- The Ancient BRZ Sacrament by Zaku |
#14 | |
Also you can add a gallon of 93 petrol to full tank of E85 to dilute E% in winter just keep overall E% about about E60 Last edited by steve99; 05-01-2015 at 10:59 PM. |
| Afe Pro Dry S air filter users | tracerit | Engine, Exhaust, Transmission | 9 | 07-17-2015 11:33 AM |
| Why have so many users been banned? | xuimod | Site Announcements / Questions / Issues | 9 | 03-08-2015 02:23 PM |
| Firefox users | V_86 | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 01-03-2015 07:42 PM |
| E-85 users thread | Crossover Auto | Engine, Exhaust, Transmission | 41 | 11-16-2012 07:21 PM |
| Rwd toyota users here? | aphxero | Other Vehicles & General Automotive Discussions | 14 | 12-23-2009 09:34 PM |
