Old 04-28-2015, 09:43 AM   #15
fika84
fika84's Avatar
Originally Posted by Gopherboy6956 View Post
Haha thanks.
I have just those fuel lines and the transmission to unbolt, then i'm ready to yank the engine. All in all, it's really not that bad of a process, even for someone who's never done it before. Now, finding the reason I have oil in cyl 1 will be another task in an of itself.
Just take your time, use the PROPER tools so you don't break anything and you will be fine! Are you boosted?
fika84 is offline   Reply With Quote
Old 04-28-2015, 09:45 AM   #16
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Yes. I have the Vortech Kit, and had it on for about 4500 miles before i started smoking a week ago.
Here's the story: http://www.ft86club.com/forums/showthread.php?t=87235
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following 2 Users Say Thank You to Gopherboy6956 For This Useful Post:
chaoskaze (04-30-2015), fika84 (04-28-2015)
Old 05-02-2015, 02:00 AM   #17
Gopherboy6956
Holy. Shit.
After reading the manual on disassembling the engine, i about shit myself. Also, all the Special Service Tools are insane.
this. Is. Going. to. Suck.
Old 05-02-2015, 02:53 PM   #18
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Tok me 5 hours to remove my motor on my own.
A weekend to strip it down.
I did not have any of the special tools.
English is my 2. language. Typos might occur.
2013 BRZ, kraftwerks supercharged.
Skunk2 Ultra radiator with oilcooler
KW v3 - enkei 17x9 with PSS
Andreas83 is offline   Reply With Quote
Old 05-02-2015, 02:54 PM   #19
Gopherboy6956
Originally Posted by Andreas83 View Post
Tok me 5 hours to remove my motor alene.
How about building it back up? I see a ton of non reusable o-rings and sealants.
Old 05-02-2015, 07:03 PM   #20
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I am in the middle of removing and dropping in a new motor myself.
I used this tool to disconnect the fuel lines: http://www.company23.com/545
It worked well enough. And is pretty much the only special tool I used. To lift the motor, I went to ACE and got a bolt that fit the front threaded hole in front of the throttle body that the service manual mentions rather than the $50 tool and $5 bolt (which cross references to like, a suspension a-arm on a 4runner or something).
The procedure listed in the service manual ISO is pretty good, actually. I wasn't going to re-use my motor, but tore it down anyways to get a good look at it.
Getting the timing cover off is about the hardest part. I used a plastic scraper/spudger to force the cover and motor apart and cut the silicone with a utility knife. You probably aren't going to need to remove the cam sprockets, since you can just remove the entire cam carrier section of the head.
FrX is offline   Reply With Quote
Old 05-02-2015, 07:32 PM   #21
Gopherboy6956
Yep, I got the fuel line disconnect from harbor freight. Almost to the cylinders now. That timing cover was a bitch.
I'm down to the head bolts, had to go pickup 12pt sockets.
Old 05-03-2015, 01:23 AM   #22
Andreas83
Andreas83's Avatar
Replaced all seals and used new sealant.
I replaced the crank, rods and all bearings.
Make sure to bag and tag all the parts.
I had my girlfriend helping me when i stripped the motor.
Just handed her the parts, she put them in plastic bags with a postit describing were it belonged.
Building the motor took me longer, but I double checked everything.
The Following User Says Thank You to Andreas83 For This Useful Post:
BRZ RN (03-23-2016)
Old 05-03-2015, 10:17 AM   #23
FrX
I did the same exact thing. I use a ton of zip-loc bags and labeled them with a Super Sharpie (oil will dissolve the normal ones' ink).
Old 05-03-2015, 03:47 PM   #24
Gopherboy6956
I've also been bagging parts.
I'm pretty comfortable tearing it all down (now that i've gotten to the pistons) but building it back up seems daunting. Did you clean all the parts before re-assembly? what kind of specialty tools did you need to complete that?
Here's where i'm at now: http://www.ft86club.com/forums/showp...5&postcount=40
Old 05-04-2015, 12:53 AM   #25
Andreas83
Andreas83's Avatar
Everything was cleaned.
Used a drill wire brush to remove gasket sealant.
Brake cleaner and high pressure air to remove oil and other debris.
Make sure that all oil gallys are clean.
Used a tin can that squirts oil and applied it during assembly.
I used almost a bag of rags during assembly.
Plastigauge to check bearing clearence on crank, rods & camshafts.
You need some "special" tools.
Torque wrench, feeler gauges, piston ring compressor and some other tools.
I had everything neded in my work shop.
Old 05-04-2015, 01:02 AM   #26
Gopherboy6956
Did you split the block?
Old 05-04-2015, 01:45 AM   #27
Andreas83
Andreas83's Avatar
Yes. I had a spun rod bearing.
Replaced crank, rods and bearings.
Old 05-04-2015, 01:46 AM   #28
Gopherboy6956
What pistons did you go back with? Pen crank? Was it spendy?
FS: Password JDM Engine Covers and Gunmetal Engine Dress Up kit PrimeMotoring Engine, Exhaust, Bolt-Ons 10 11-25-2014 11:38 PM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
