Old 04-29-2015, 01:13 PM   #15
Teseo
Drives: frs
In for a thread: "I traded in frs for mustang and now i regret it"
The Following 4 Users Say Thank You to Teseo For This Useful Post:
flippy (05-01-2015), GotBRZ1691 (05-01-2015), pLaydEad86 (04-29-2015), Tcoat (04-29-2015)
Old 04-29-2015, 01:33 PM   #16
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by Teseo View Post
In for a thread: "I traded in frs for mustang and now I'm way faster"
fixed lol
Old 04-30-2015, 11:44 AM   #17
colzfrs
A girl can Auto Cross
colzfrs's Avatar
Drives: Hot Lava 2013 FR-S
I had to have my ecu reflashed and it helped. Can't tune it with that problem cause it needs to be reflashed first. It is a known issue and they will take care of u at scion just let them know. I do believe this is something that is a report so scion will fix the issue. Just make sure u have no aftermarket intake on when u bring it in.
colzfrs is offline   Reply With Quote
Old 04-30-2015, 12:10 PM   #18
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by colzfrs View Post
Can't tune it with that problem cause it needs to be reflashed first. It is a known issue and they will take care of u at scion just let them know..
So... you cant flash a new tune until you flash a new tune.
Got it
The Following 5 Users Say Thank You to stugray For This Useful Post:
brandonblt2 (05-01-2015), dpgfunk (05-01-2015), flippy (05-01-2015), GotBRZ1691 (05-01-2015), Tcoat (05-01-2015)
Old 05-01-2015, 05:04 AM   #19
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
More damn idle issues... About to say bye to my frs
Take it to dealer for newer ecu flash.
Mine did it when it was brand new too. I fixed it by 1. Drop in filter (the rpm drop stopped after I pop-in a drop-in air filter, though it still does it with AC on for a long time) 2. Drive it hard on track & put on some good mile (mine rpm dont fluctuate at all even with AC on now, it sorta just stop doing it all together one day after track session... At like 11k mile)
Old 05-01-2015, 11:38 AM   #20
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by spatcha88 View Post
Hey guys I think I'm almost at my last straw with this car. So was suffering from a bad idle issue and it seems it has been getting worse.. Coming to a stop the car seems to drop about 200 Rpms from 700. Now the car idle hunts constantly from 700-650. When I drop it in neutral it idles fine but in reverse or drive (auto) it seems to drop to 500 rpm like it's coming to a stall then jumps back to the 650-700 rpm range and I get a bit of engine shake. Same when coming to a stop. I called a shop and they believe it might be bad DI injectors not too sure without them looking at it. Also the car is no longer under warranty.
I'm about to buy an oft but not sure if that will help or will it? Either way anyone else having this issue? If I don't find a fix for this in 2 weeks I'm leaving the frs scene.
With an auto tranny, when you are in D or R, there is a load on the engine. That's why you have to hold the brake...the car is trying to move. You are not really "idling".
billwot is offline   Reply With Quote
Old 05-01-2015, 02:15 PM   #21
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
How many miles are on the car? The 13's are known to have this problem(one of many). If you just bought it a few months ago, the dealer should have reflashed the car before selling it to you. They failed to do this, so it should be done at no cost to you.
My car has had almost all of the issues and im not letting it go. There are countless ways to fix the common problems and there is an endless amount of threads on how to do so.
Always research before picking up a car. The idle issue is nothing and can be fixed easily.
But if you are put off and want to sell the car based on this little problem now, do it before other issues that are actually serious happen.
I've been through two fuel pumps, about to get my third transmission, had both tail lights replaced, and now have a weird vibration sound right at 5,400 to 5,700 rpms.
GotBRZ1691 is offline   Reply With Quote
Old 05-01-2015, 02:16 PM   #22
GotBRZ1691
GotBRZ1691's Avatar
In for a thread: "I traded in frs for mustang and now im way faster, in a straight line"
@Shutter
fixed the fix
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
continuecrushing (05-01-2015)
How to fix the idle issues...according to jalopnik jeebus BRZ First-Gen (2012+) — General Topics 17 10-11-2012 05:06 PM
With all these CEL/idle, chirp issues, should I postpone buying? Iixii Issues | Warranty | Recalls / TSB 31 10-11-2012 04:18 PM
Scion FR-S, Subaru BRZ rough idle issues require ECU reflash gunitrecord BRZ First-Gen (2012+) — General Topics 1 10-06-2012 02:14 AM
Is there a way compel Toyota/Subaru to reveal what they know about CEL/Idle issues? @Art_Mighty Issues | Warranty | Recalls / TSB 20 09-24-2012 09:37 PM
Anyone worried about chirping/idle/taillight condensation issues? JDM-dono AUSTRALIA 31 07-21-2012 01:12 AM
