Old 04-28-2015, 07:54 PM   #1
spatcha88
Drives: 2013 Scion FRS Whiteout
More damn idle issues... About to say bye to my frs
Hey guys I think I'm almost at my last straw with this car. So was suffering from a bad idle issue and it seems it has been getting worse.. Coming to a stop the car seems to drop about 200 Rpms from 700. Now the car idle hunts constantly from 700-650. When I drop it in neutral it idles fine but in reverse or drive (auto) it seems to drop to 500 rpm like it's coming to a stall then jumps back to the 650-700 rpm range and I get a bit of engine shake. Same when coming to a stop. I called a shop and they believe it might be bad DI injectors not too sure without them looking at it. Also the car is no longer under warranty.
I'm about to buy an oft but not sure if that will help or will it? Either way anyone else having this issue? If I don't find a fix for this in 2 weeks I'm leaving the frs scene.
spatcha88 is offline   Reply With Quote
Old 04-28-2015, 07:58 PM   #2
raven1231
Do you have an aftermarket intake? Injen has been known for this issue? Also, how long has this been going on? Early 2013's had an issue with this until they were reflashed by the dealer to the latest map.
Old 04-28-2015, 08:03 PM   #3
spatcha88
Well I bought the car a couple months back and the issue has always been happening since I picked up the car. Also negative on the intake. All stock.
Old 04-28-2015, 08:11 PM   #4
raven1231
OFT might help if It is indeed the tune as they all have the update built into their maps.
Old 04-28-2015, 08:12 PM   #5
raven1231
This is what I was referring to- http://jalopnik.com/5948647/heres-ho...s-idle-problem
Old 04-28-2015, 08:15 PM   #6
whataboutbob
AutoX-10/10ths every run
Are you running the AC when this happens?
Build thread:Here
Old 04-28-2015, 08:19 PM   #7
swarb
What shops have you actually taken it to?
And what have you tried to fix/inspect/swap out?
Old 04-28-2015, 08:21 PM   #8
spatcha88
Does it with ac on or off
Old 04-28-2015, 08:25 PM   #9
swarb
May 12th
Old 04-28-2015, 08:53 PM   #10
This^^^^
If you bought used the reflash that fixes it may never have been done. If it has been doing this all along then that should have been the first thing to check.
Old 04-28-2015, 08:58 PM   #11
stevesnj
stevesnj's Avatar
Maybe something with the smart-stop feature?
My 2016 Build thread
Old 04-29-2015, 05:12 AM   #12
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Any idea what ecu version your car has? I had pretty gnarly fluctuation whenever i turned on the HVAC, mostly with the rear defroster. Car had A01 from factory, recall on these warranted me with an update at a local dealer to B01 map. Seems to have fixed most of the issue. How many miles do you have?
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 04-29-2015, 12:31 PM   #13
Ashikabi
Ashikabi's Avatar
It's your car rejecting the automatic transmission.
Jk I dunno what's wrong. Sounds like a tune will fix it since all this stuff is run by the ECU
Old 04-29-2015, 12:41 PM   #14
stugray
Drives: 2013 GBS BRZ Limited
Step #1 - Find out what ROM you have and see if there is an update.
If there IS, dealer will likely update it for free even if car is out of warrantly period.
If that does not solve your problem, then
Step #2 - Get an ELM327 OBD Bluetooth module from ebay and the torque app and log some data & post the logs.
If the problem is STILL not resolved, get a OFT or Tactrix & update your ROM to OFT stage 1
The OFT tune will bump your idle RPM a little (or you can do it yourself)
How to fix the idle issues...according to jalopnik jeebus BRZ First-Gen (2012+) — General Topics 17 10-11-2012 05:06 PM
With all these CEL/idle, chirp issues, should I postpone buying? Iixii Issues | Warranty | Recalls / TSB 31 10-11-2012 04:18 PM
Scion FR-S, Subaru BRZ rough idle issues require ECU reflash gunitrecord BRZ First-Gen (2012+) — General Topics 1 10-06-2012 02:14 AM
Is there a way compel Toyota/Subaru to reveal what they know about CEL/Idle issues? @Art_Mighty Issues | Warranty | Recalls / TSB 20 09-24-2012 09:37 PM
Anyone worried about chirping/idle/taillight condensation issues? JDM-dono AUSTRALIA 31 07-21-2012 01:12 AM
