Old 04-21-2015, 01:09 PM   #1
ironhorse2118
Drives: 2013 FRS asphalt
switchback install
okay well i bought my FRS a month ago and it already had switchback's installed, well one decided to stop working so i need to take them out and just put the stock bulbs back in, the question is how to i get the LED's out? do i have to take off the whole bumper?
ironhorse2118 is offline   Reply With Quote
Old 04-21-2015, 01:30 PM   #2
NickDC88
NickDC88's Avatar
Turn your wheels the opposite way, take a few of the fender liner clips out and reach in.
NickDC88 is offline   Reply With Quote
Old 04-21-2015, 01:33 PM   #3
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
1. Turn the wheel to the left or right depending on which side you're removing.
2. Remove the bottom three plastic screw retainers on fender liner.
3. Pull fender liner back.
4. Reach in and grab the bulb housing.
5. Twist to disconnect the bulb housing.
6. Remove bulb and replace.
7. Repeat steps in reverse.
Should take about 10 minutes tops.
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
leoh007 (04-21-2015)
Old 04-23-2015, 10:06 AM   #4
ironhorse2118
got it, thanks guys
Old 04-24-2015, 10:11 AM   #5
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
If you haven't put the stock ones back yet, you should try just unplugging the LED for like a minute and then plug it back in and see if it works. Mine have stopped working a few different times, but when I unplug and then plug it back in, they start working again lol. Just a thought.
J.B.
golfyankee2121 is offline   Reply With Quote
Old 04-24-2015, 04:45 PM   #6
Tbird232ci
Drives: 2013 FRS
J.B.
Typically that's a sign of a bad connection on the LED.
I few years back, I bought some cheapie LEDs from ebay, they would flicker after a while. I would have to push them back into the sockets and they would be good for a week or two. After that, I said screw it and put stock bulbs back in.
Tbird232ci is offline   Reply With Quote
Switchback LED Question rmbstyle Cosmetic Modification (Interior/Exterior/Lighting) 3 01-28-2015 04:01 PM
LED Switchback question. AintTrying2Race Cosmetic Modification (Interior/Exterior/Lighting) 8 07-03-2013 04:33 PM
Need Help w/ Switchback LED! bhbnuckle Cosmetic Modification (Interior/Exterior/Lighting) 1 04-30-2013 11:10 AM
switchback LED assistance Gen Cosmetic Modification (Interior/Exterior/Lighting) 2 10-09-2012 11:41 PM
Switchback LED's SocalBurt Cosmetic Modification (Interior/Exterior/Lighting) 7 09-03-2012 02:37 PM
