Old 04-20-2015, 06:27 PM   #29
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Synack View Post
Redline it as much as you want. Just don't do it like 50 times a day. I probably do it 20 times.
If that were true no car would survive more than a few track days where you spend nearly 20 minutes straight above 5k rpm and you're >7k rpm around 10 instances per lap (at my local) or ~100 times in that 20 minute session.
And it's typical to do that 5x in a track day... I've been above 7k rpm >500x in a single day. My car is at 37k miles with the only issue being a coil pack that needed replacing.
If this engine can't handle that long term expect this car to get dropped by thousands of people.
ineedyourdiddly
Old 04-20-2015, 06:35 PM   #30
Tromatic
I was told that my typical fourth-gear highway driving (uphill most of the way, full of dumbasses) would blow my engine up.
The Following User Says Thank You to Tromatic For This Useful Post:
strat61caster (04-20-2015)
Old 04-20-2015, 06:50 PM   #31
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Not the water temp, the OIL. Give it a good 15-20 minutes before dropping the hammer.
http://www.ft86club.com/forums/showp...46&postcount=7
In my car it averages less than 10 minutes for the oil to warm up when driving slowly (less than 1/3 throttle application).
-alex
Old 04-20-2015, 07:17 PM   #32
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Originally Posted by awhatzable View Post
So it safe to red line from 1st,2nd,3rd or 4th gear once everyday ?
The limit is 14 times per day. After that your warranty is voided.
ntron1 is offline   Reply With Quote
Old 04-20-2015, 08:25 PM   #33
Tromatic
I took the faceplate off, used a black sharpie and covered the red stuff. Instant nine grand redline!
The Following 3 Users Say Thank You to Tromatic For This Useful Post:
Strife26 (04-21-2015), Tcoat (04-20-2015), Ultramaroon (04-20-2015)
Old 04-20-2015, 08:27 PM   #34
Video DIY please.
Old 04-20-2015, 08:38 PM   #35
Tromatic
Video DIY please.
I just broke the faceplate with a hammer. The car does suck after all, why take care of it.
brandonblt2 (04-22-2015), Tcoat (04-20-2015), Ultramaroon (04-20-2015)
Old 04-20-2015, 10:42 PM   #36
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
If your temps are up to operating temps. Not just coolant gauge on dash but oil. And such.
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
Old 04-20-2015, 11:26 PM   #37
-alex
Somewhere I read @CSG Mike say the oil temp lagged several minutes behind the water temp as the engine warmed up. Is that your experience?
Old 04-20-2015, 11:47 PM   #38
mav1178
mav1178's Avatar
Allow myself to quote.... myself.
Adding to above points...
I have the Pivot Dual Gauge (review link), and having driven it for a few days in Southern California weather I can safely say the following:
- Ambient starting temps are around 25-30C for both fluids. Car is garaged and ambient air temps are around 55-60F.
- 30 second warmup + ~90 seconds of < 3000 RPM driving gets the needle to the first mark on dash temp gauge. At this point the Pivot gauge reads 60C water temp and around 50C oil temp.
- A total of around 4 minutes is needed for easy driving to get the thermostat to open up around ~70C. The oil temp stays around 60-65C
- Largest delta between coolant and oil temps was around 20 degrees, when the coolant hits 80 but oil temp still is barely 60-ish
Results may vary, but it's safe to say that with easy driving + 30 second warmup, you're looking at roughly 5 seconds for each degree centigrade increase in oil temp from a completely cold engine. Coolant may take longer to warm up if you have the AC on.
-alex
FRSupra (04-21-2015)
Old 04-20-2015, 11:50 PM   #39
<self facepalm> I never made it past stugray's plot. (ooo shiny)
sorry & thanks!
CSG Mike (04-21-2015)
Old 04-21-2015, 12:37 AM   #40
Tromatic
Carista shows about five minutes to "normal" operating temps as well.
Ultramaroon (04-21-2015)
Old 04-21-2015, 01:11 AM   #41
15 minutes for me before water temp stabilizes in the morning. When it gets there it's rock solid. I try to wait an extra few minutes after the pedal dance engages before I start the wankfest.
Old 04-21-2015, 04:34 AM   #42
Tromatic
Just don't rest your hand on the knob, causes all kinds of problems.
The Following 2 Users Say Thank You to Tromatic For This Useful Post:
Strife26 (04-21-2015), Ultramaroon (04-21-2015)
Possible to reach fumoto without lifting? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-23-2014 04:36 PM
Tryong to reach Tony from FA20club infanterene Forced Induction 2 07-31-2013 08:16 PM
The seating position of BRZ is too low to reach at a drive-through-ATM yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 28 07-16-2012 02:18 PM
First to reach 1,000 miles? dietz Scion FR-S / Toyota 86 GT86 General Forum 22 05-31-2012 11:43 AM
