Old 04-06-2015, 12:50 PM   #15
Tal
Tal's Avatar
Drives: Scion FRS 10 Series
Yes yes it is.
10 Series Owner. Love it.
Tal is offline   Reply With Quote
The Following User Says Thank You to Tal For This Useful Post:
Tcoat (04-06-2015)
Old 04-06-2015, 01:03 PM   #16
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by Tal View Post
The tight wound coil is facing up not Down. And I'll loosen everything lower the car and tighten everything again. You think that'll fix it?
Maybe. The only way to know is to try. I believe the tighter woindingd sould be at the top. I don't have the springs to confirm. I have Swift Spec R's.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-06-2015, 01:06 PM   #17
Thorpedo
The SquadWhisperer
+1 for tightening suspension with the weight on the wheels.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 04-06-2015, 01:13 PM   #18
Tal
Tal's Avatar
You think that'll help?
Old 04-06-2015, 01:37 PM   #19
simpleisbest
Senior Citizen
Drives: Scion FR-S
How many miles have you had on the car since installation? The springs do settle a bit. Also, note the installation instructions. IIRC, they recommend specific spacing between the spring seat "stop" when building the coilover. The spacing probably gives room for the springs to settle and prevent bind.
simpleisbest is offline   Reply With Quote
Old 04-06-2015, 01:56 PM   #20
Tal
Tal's Avatar
Well I'm not sure how many miles but I'll make sure they have space. But they shouldn't stay stock height. Ugh lol
Old 04-06-2015, 02:53 PM   #21
Thorpedo
The SquadWhisperer
By tightening the bolts with the suspension fully extended you are creating a condition in many bushings that resists the compression of the suspension (due to the fact that the rubber bushings must twist as the suspension compresses). This raises ride height.
There is only one bushing in the front that would contribute to this effect, in the rear there are 8 (per side). End link lower, lca inner, strut lower, toe rod inner, lateral arm front and rear, and both inner upper control arm bushings.
Old 04-06-2015, 02:54 PM   #22
Tal
Tal's Avatar
OK so should I also loosen the top of the strut?
Old 04-06-2015, 03:24 PM   #23
Racecomp Engineering
You should take some pictures. Of the car and the springs mounted.
- Andy
Old 04-06-2015, 03:32 PM   #24
Tal
Tal's Avatar
- Andy
Alright I'll rake the pictures as soon as I can.
Old 04-06-2015, 03:32 PM   #25
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
If it were my car, I'd pull the wheels off, check the color and orientation of the springs... then put a torque wrench on every bolt accessible (following the service manual's recommended torques).
Drive the car for a couple days, and re-check the torque. Twisting on the bushings is a thing... but it shouldn't stay too bound-up after a little driving.
BTW, if you're talking about loosening the top nut, just make sure there are plenty of threads engaged. This is no fun:
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 04-06-2015, 03:51 PM   #26
Thorpedo
The SquadWhisperer
Was that in my list?
"twisting on the bushings is a thing... but it shouldn't stay too bound-up after a little driving." - No matter how much you drive it is still twisting the bushing the same amount. After time the bushing can stretch and deform (which is bad) and that may allow it to settle. You're asking for bushing damage though.
Old 04-06-2015, 04:05 PM   #27
Tal
Tal's Avatar
OK basically tighten everything once the car is on the ground. Got it!
Thorpedo (04-06-2015)
Old 04-08-2015, 06:55 PM   #28
Tal
Tal's Avatar
OK guys, I tightened everything and I'm gonna let it sit for a week. However now I hear squeaking going on every time I go over some bump. Any ideas!
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 03:18 PM
Question about these springs? TomT2411 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-23-2014 03:29 PM
Swift Sport springs/or any springs.. regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-21-2014 09:10 PM
Lowering Springs Question Ymerej Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-22-2014 09:24 PM
Newb question- springs vs coilovers wbradley Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-12-2012 10:09 AM
