Old 04-02-2015, 08:18 PM   #1
Tal
Tal's Avatar
Drives: Scion FRS 10 Series
TRD Springs question
Ok, so i installed TRD springs about 2 weeks ago. The front end lowered, however the back end did not. I compared it to a lowered stock FRS on the same springs at the dealership. The guys at the shop and I reinstalled them about 3 times and nothing, we think its just that there is no weight in the back. What do you guys think? Anyone have this issue?
10 Series Owner. Love it.
Tal is offline   Reply With Quote
Old 04-02-2015, 08:29 PM   #2
Estey
Drives: Scion FR-S, Ultramarine
It has nothing to do with weight in the back, and if the shop thinks so then I suggest you find a new shop.
do you have any pics?
Estey is offline   Reply With Quote
The Following User Says Thank You to Estey For This Useful Post:
wparsons (04-03-2015)
Old 04-02-2015, 08:30 PM   #3
Tal
Tal's Avatar
I do not but the rear height is the same as stock...
Old 04-02-2015, 08:33 PM   #4
Estey
I have no idea, unless the shop didnt install the rear springs..
it just doesnt make any sense, especially since the trd's are just rebranded eibach's.. did you buy new or used?
Old 04-02-2015, 08:35 PM   #5
Tal
Tal's Avatar
I bought new, and I was right there with them when installing happened because I work there, do you think it just needs to be compressed more?
Old 04-02-2015, 08:41 PM   #6
Estey
I really hope you arent trolling, haha
springs dont need to be compressed once theyre installed.
Old 04-02-2015, 08:42 PM   #7
Tal
Tal's Avatar
I'm seriously not trolling. Like it's been bothering me so much.
Old 04-02-2015, 08:47 PM   #8
Estey
Try and post pictures of how your car sits when you can!
Old 04-02-2015, 08:51 PM   #9
Tal
Tal's Avatar
OK, but i did use a tape measure and its stock height in the back, it pisses me off.
Old 04-02-2015, 09:17 PM   #10
8R6
8R6's Avatar
Drives: FRS
is the rear spring seated in its perch properly?
8R6 is offline   Reply With Quote
Old 04-03-2015, 03:33 AM   #11
Nickel
Nick
Drives: 2013 10 Series GT86 #182 of 2500
Mine are different on my 2013. The car is lower but it almost looks like the rear is lower than the front. Maybe give them time to settle and see what happens?
2013 Scion FR-S 10 Series MT #182 of 2500/2007 BMW Z4 3.0si Coupe/2016 Yamaha FZ-09/2022 Ford Mustang Mach 1 Handling Package MT Recaro 700A (#N3956)/2023 Toyota Camry XSE
Instagram: @the_white_comet_of_zion
Nickel is offline   Reply With Quote
Old 04-03-2015, 11:22 AM   #12
wparsons
wparsons's Avatar
I'd make sure they're seated properly, and also validate it is the TRD springs installed and not the stock ones. It would be really hard to install them so wrong that it's riding an inch too high.
flickr
Old 04-03-2015, 12:04 PM   #13
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I think thy were installed upside down so the spring isn't seated. I can't iamgine anything else. Unless the tightened everything without weight on the car so all the bushings are binding way too early.
Put everything together by hand then make sure the full weight of the car is on the suspension before you torque it to spec.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 04-06-2015, 12:48 PM   #14
Tal
Tal's Avatar
The tight wound coil is facing up not Down. And I'll loosen everything lower the car and tighten everything again. You think that'll fix it?
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 03:18 PM
Question about these springs? TomT2411 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-23-2014 03:29 PM
Swift Sport springs/or any springs.. regrets ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-21-2014 09:10 PM
Lowering Springs Question Ymerej Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-22-2014 09:24 PM
Newb question- springs vs coilovers wbradley Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-12-2012 10:09 AM
