Old 04-04-2015, 01:21 PM   #15
Originally Posted by jsimon7777 View Post
I was. I put a smiley at the end. Have you not ever worked in tech support?
"Is it plugged into the wall?"
"Of course! I'm not stupid."
"Is it plugged into the computer too?"
"Oh snap!"
Haha... yes! I should have put a smiley or winky on mine too. I was going for the "be niiiiice..." just for laughs.
Old 04-04-2015, 04:42 PM   #16
spatcha88
Drives: 2013 Scion FRS Whiteout
jeez. you ft guys are so so nice
spatcha88 is offline   Reply With Quote
Old 04-04-2015, 05:02 PM   #17
Sorry, now I'm lost. ft? forum troll?
You pretty much have your answer. Dealer blew you off. That was a very early firmware tweak.
cdrazic93 (04-04-2015), swarb (04-04-2015)
Old 04-04-2015, 05:17 PM   #18
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
To be fare, other things could cause the issue. Or the previous owner could have flashed back to an older ROM for some reason. Perhaps they had an OFT, had the dealer flash it, and before selling, had OFT put it back to stock? Lots of stupid things can happen.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Ultramaroon (04-04-2015)
Old 04-04-2015, 06:06 PM   #19
Teseo
Drives: frs
I bet for dealer stupidity
The Following User Says Thank You to Teseo For This Useful Post:
Old 04-04-2015, 06:33 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You should sue the dealer for being stupid.
Man I wish that was grounds for legal action, I would have put so many people in jail by now...
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 04-04-2015, 07:04 PM   #21
spatcha88
Yeah I'm going to have to take it in to a different dealer. These guys were idiots.
Old 04-04-2015, 07:07 PM   #22
spatcha88
No I'm not trolling. I'm just really annoyed with my car right now my bad man. Since I picked up this car I've had several little annoying issues that I'm fixing every other week. This is just the most annoying issue I have with my car so far that I just want fixed!
Old 04-04-2015, 07:27 PM   #23
alan.chalkley
Drives: 4wd zooks
Mine had the same problem after the second routine service , only worse , it would idle rough and stall.
I took it straight back and they read an idle failure code and did a reset , by battery disconnect/reconnect.
It took 200 kms to relearn fuel trim and idle and has been running perfectly since.
I can only assume that the young apprentice used toooo much throttle body cleaner and/or forgot to reconnect the MAF sensor.
For the next "free" service , I will request an experienced mechanic!
alan.chalkley is offline   Reply With Quote
Old 04-04-2015, 07:43 PM   #24
no no, you said ft first but I don't know what that means. I was sort of trolling but only because you had your answer.
It's all good.
Old 04-04-2015, 09:53 PM   #25
Estey
Drives: Scion FR-S, Ultramarine
It's all good.
Im laughing at the fact that everything you said was misinterpreted
Estey is offline   Reply With Quote
The Following User Says Thank You to Estey For This Useful Post:
Old 04-04-2015, 10:14 PM   #26
Old 04-04-2015, 10:36 PM   #27
spatcha88
I havn't tried cleaning my throttle body at all yet. I'm going to try just resetting the battery.
Old 04-06-2015, 06:32 PM   #28
muffinz
Drives: 2013 DGM BRZ Ltd
Does it happen 100% of the time or only when the A/C is on?
my car doesn't do it at all unless the A/C is on...
basically the compressor kicks in during the slow down with the clutch engaged (aka 0% fuel injection) and it makes the RPMs drop past idle causing it to stutter for a second before the car reintroduces fuel.
I wouldn't worry about it if this is the case.
muffinz is offline   Reply With Quote
SOLVED: Idle Dip only when coming to a stop? spatcha88 Issues | Warranty | Recalls / TSB 38 04-14-2015 12:16 AM
Do you ever feel like an asshole for coming to a complete stop? Ozzman Off-Topic Lounge [WARNING: NO POLITICS] 53 01-20-2014 12:35 AM
Difficult to shift into first when coming to a stop ZackZ Scion FR-S / Toyota 86 GT86 General Forum 21 08-31-2013 12:05 PM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 07:34 PM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
