Old 04-01-2015, 08:07 PM   #1
spatcha88
Drives: 2013 Scion FRS Whiteout
SOLVED: Idle Dip only when coming to a stop?
Hey guys having this weird issue for the past month now. Past 2 mechanics can't figure it out. As I'm coming to a stop my car shakes a bit and rev vips about 100-250 rpms then goes back to normal after coming to a complete stop. This happens during start up and goes away after 15/20 minutes of driving. I just redid my spark plugs/coil packs and have 41k miles. It almost feels like a vacuum leak of some sort. Anyone have any idea on what I should look for?
Edit 04/16/2015:
So I took the Intake Hoses out and saw the throttle body had a shit ton of gunk in it. Outside of butterfly spacer and inside.. Seems like the gunk was literally at the rim of the butterfly and may have been the culprit. I sprayed MAF cleaner and wiped it clean and let it dry off for an hour. She is purring like a god damn kitten now baby! I'm glad I managed to fix this myself without throwing more money at a mechanic / dealer. I just hope the problem doesn't come back. Will keep you all posted in a hundred miles! BTW Warning: Please be FRIGGEN CAREFUL when cleaning your TB.
spatcha88 is offline   Reply With Quote
Old 04-01-2015, 08:33 PM   #2
vividracing
vividracing's Avatar
Do you have an aftermarket air intake by chance?
-RyanG
vividracing is offline   Reply With Quote
Old 04-01-2015, 09:36 PM   #3
spatcha88
-RyanG
Negative on the intake. Still stock. Only bolt on so far is my exhaust. But this issue has been happening long before I got the exhaust installed (2 weeks ago.) Since I first purchased the car it's been doing it. At first I assumed it was just cold start. But it never went away :|
Old 04-01-2015, 09:40 PM   #4
navanodd
Drives: 2013 BRZ Sport-tech WRB
ECU calibration on some of the 2013's did this. I had the dealer flash the latest version and it went away.
navanodd is offline   Reply With Quote
Old 04-01-2015, 09:43 PM   #5
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
This...take it to the dealer and ask them to check for the rough idle service bulletin.....that should fix it.
MightyMeeple is offline   Reply With Quote
Old 04-01-2015, 10:11 PM   #6
BRZnut
Drives: BRZ DGM Limited
My 2013 has done this from day one buy never drops below 500 RPM and never makes the car shake, so never did anything about it.
I notice that it is more likely to occur with sudden stops. Less likely with gradual stops.
Old 04-02-2015, 09:17 AM   #7
fasteddy
I had this problem, dealer reflash fixed it.
Pat
fasteddy is offline   Reply With Quote
Old 04-02-2015, 09:52 AM   #8
Kfresh23
Kfresh23's Avatar
Drives: 2013 WRB Subaru BRZ
Mine also did this, and my dealer said it was due to my AC compressor kicking in/out. I was not impressed with this response as the car should not "almost stall" in idle, regardless of the compressor coming on. I did notice that with the AC turned off, it was not as bad.
Issue has gotten better in time.
Kfresh23 is offline   Reply With Quote
Old 04-05-2015, 07:01 PM   #9
brianhj
Drives: 2017 Camaro 1SS
Mine does it even after a tune. Like Kfresh23 said it's not as bad with the a/c off.
brianhj is offline   Reply With Quote
Old 04-06-2015, 02:12 PM   #10
ImBatman
My Tumbler is an FRS
Drives: exclusively in the fast lane
^ THIS ^
Pop the hood and start your car. You'll see/hear the idle dip you're talking about when the A/C compressor kicks on/off.
AFAIK it's not an issue, just a quirk.
ImBatman is offline   Reply With Quote
Old 04-06-2015, 02:30 PM   #11
Shady195
Drives: '13 10 Series FRS #1203
A small "dip" is common in any car when the A/C compressor kicks on..
However the hard dip when the car shakes was fixed in a service bulletin as stated. Or you can buy an OFT and flash a tune.
Its not going to hurt the car, just a minor annoyance.
Shady195 is offline   Reply With Quote
Old 04-06-2015, 05:51 PM   #12
ninedice
ninedice's Avatar
Drives: Series 10 #177 M/T
Mine does this as well. Dealer reflashed and it still does it. Annoying.
ninedice is offline   Reply With Quote
Old 04-06-2015, 07:33 PM   #13
brianhj
What the fuck is the point of the a/c compressor cycling on and off literally every 5 seconds? Is there a good reason for it?
Old 04-06-2015, 08:13 PM   #14
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Keeps it cool when you aren't moving.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Do you ever feel like an asshole for coming to a complete stop? Ozzman Off-Topic Lounge [WARNING: NO POLITICS] 53 01-20-2014 12:35 AM
Difficult to shift into first when coming to a stop ZackZ Scion FR-S / Toyota 86 GT86 General Forum 21 08-31-2013 12:05 PM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 07:34 PM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 06:16 PM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
