| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Haha... yes! I should have put a smiley or winky on mine too. I was going for the "be niiiiice..." just for laughs.
#16 |
Drives: 2013 Scion FRS Whiteout
#17 |
#18 |
Dismember
Drives: 2013 Red Scion FR-S
To be fare, other things could cause the issue. Or the previous owner could have flashed back to an older ROM for some reason. Perhaps they had an OFT, had the dealer flash it, and before selling, had OFT put it back to stock? Lots of stupid things can happen.
#19 |
Drives: frs
I bet for dealer stupidity
#20 |
Junior
Drives: a car
You should sue the dealer for being stupid.
Man I wish that was grounds for legal action, I would have put so many people in jail by now...
#21 |
Yeah I'm going to have to take it in to a different dealer. These guys were idiots.
#22 |
No I'm not trolling. I'm just really annoyed with my car right now my bad man. Since I picked up this car I've had several little annoying issues that I'm fixing every other week. This is just the most annoying issue I have with my car so far that I just want fixed!
#23 |
Drives: 4wd zooks
Mine had the same problem after the second routine service , only worse , it would idle rough and stall.
I took it straight back and they read an idle failure code and did a reset , by battery disconnect/reconnect. It took 200 kms to relearn fuel trim and idle and has been running perfectly since. I can only assume that the young apprentice used toooo much throttle body cleaner and/or forgot to reconnect the MAF sensor. For the next "free" service , I will request an experienced mechanic! |
#24 | |
It's all good.
#25 |
Drives: Scion FR-S, Ultramarine
#26 |
#27 | |
#28 |
Drives: 2013 DGM BRZ Ltd
Does it happen 100% of the time or only when the A/C is on?
my car doesn't do it at all unless the A/C is on... basically the compressor kicks in during the slow down with the clutch engaged (aka 0% fuel injection) and it makes the RPMs drop past idle causing it to stutter for a second before the car reintroduces fuel. I wouldn't worry about it if this is the case. |
| SOLVED: Idle Dip only when coming to a stop? | spatcha88 | Issues | Warranty | Recalls / TSB | 38 | 04-14-2015 12:16 AM |
| Do you ever feel like an asshole for coming to a complete stop? | Ozzman | Off-Topic Lounge [WARNING: NO POLITICS] | 53 | 01-20-2014 12:35 AM |
| Difficult to shift into first when coming to a stop | ZackZ | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 08-31-2013 12:05 PM |
| Shifter clicking when coming to a stop | larryt1026 | Issues | Warranty | Recalls / TSB | 1 | 07-15-2013 07:34 PM |
| Single knock when coming to a stop | oops86 | Issues | Warranty | Recalls / TSB | 14 | 08-05-2012 01:17 AM |
