Old 03-27-2015, 11:16 PM   #1
Venz1028
Drives: 2015 WRB BRZ
Shifter rattles after CF driveshaft install?
I've recently got my DSS CF Driveshaft installed for my 2015 BRZ.
It drives fine at any given speed. However, whenever I go over 4k RPM the shift starts to rattle.
There is no vibrations of any sort in this car.
I've searched around any found that Shifter rattle is a common issue but my question is: did my driveshaft install cause it or is it a coincidence?
Thanks!
Venz1028 is offline   Reply With Quote
Old 03-28-2015, 12:14 AM   #2
wootwoot
Drives: FRS
Do you have an aftermarket shift lever? Kartboy, etc...?
Old 03-28-2015, 12:24 AM   #3
Crazy Drew
Drives: Smells like tires when I drive
If it's RPM relative instead of being speed relative it's not the driveshaft. I'd put the car up in the air again and check for anything loose.
Crazy Drew is offline   Reply With Quote
Old 03-28-2015, 12:26 AM   #4
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Even if you don't have an aftermarket shift lever, go under the car and check clearence from your driveshaft to your shift linkage.
Decay107 is offline   Reply With Quote
Old 03-28-2015, 01:31 AM   #5
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
Thanks!
Hi,
I had a similar rattle, and I found out that it is the pin holding the gear lever to the shift arm that causes this rattle.
Have a look here: http://www.ft86club.com/forums/showt...=58951&page=19
and
http://www.ft86club.com/forums/showt...t=13664&page=5
Good luck
Freedom is offline   Reply With Quote
Old 03-28-2015, 02:43 AM   #6
troek
troek's Avatar
Drives: 2012 Toyota 86
i had a similar rattle that would happen at 4-6k on partial throttle and it ended up being my exhaust hitting my chassis, and the vibration working its way through where the front pipe bolts to the transmission for support.
troek is offline   Reply With Quote
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
Shifter bushing install Bullnettles Engine, Exhaust, Transmission 4 06-20-2013 04:36 PM
