Drives: Scion FR-S 2013
Shifter bushing install
If I have a front-pipe, and a driveshaft coming in, should I wait to do the shifter bushing so it's all at the same time? Thank you.
Drives: 2016 STi DGM
You can answer your own question... Lol
-2014 SSM BRZ MT
Drives: 2014 Widebody Cosworth FR-S
I would, I ended up removing our one-piece driveshaft to install our shifter bushing. With the stock shaft you can drop down the carrier to give yourself enough room to install the bushing, however with you doing the driveshaft anyway, I would just wait and do them all at once
![]() Hope this helps. Thanks, Rick |
I too haven't even installed shifter bushing, tranny support etc. though I could have when I took off catted front pipe to install catless one. I totally forgot to. But then again, waiting on white line bushing to knock it all out (double the work tho)
-2014 SSM BRZ MT
| Perrin Rear Shifter Bushing Install | F1point4 | DIY (Do-It-Yourself) Guides | 55 | 10-21-2021 02:39 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
| Which shifter bushing/mount do you have? | joergasm | Engine, Exhaust, Transmission | 6 | 05-22-2013 07:27 PM |
| Whiteline transmission bushing and Perrin shifter bushing review. | Superhatch | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 12-09-2012 08:40 PM |
| Does the STI Rear Shifter Bushing fit the BRZ/FRS? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 08-27-2012 03:48 PM |
