Old 03-20-2015, 12:03 AM   #379
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by Guillaume View Post
It will. Even without oil cooler. Having an extra 10°C on your water will affect your oil temp. Don't trust me, trust your oil temp gauge. In effect, the A/C will keep your water below 100°C thanks to the 2ndary fan and thus keep the oil a tad cooler.
And your water will only rise above 92C at idle NA, so fans are useless on track for most people. Also, if you run the fans on full the Coolant won't drop below about 90.
Old 03-21-2015, 06:28 AM   #380
keen as
keen as's Avatar
Drives: 86 GT MT
Did I miss the update about the external oil cooler (and no aircon?)
Any pressure data?
Thanks for great thread/info/pics.
keen as is offline   Reply With Quote
Old 03-24-2015, 10:39 PM   #381
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Any pressure data?
Do you mean external oil pump or cooler?
The external oil pump didn't work in the configurations we tried so we had to put it back the way it was to race this past weekend. Here are a couple short clips. Enjoy.
Drag racing a C7 Z06 on the front straight https://instagram.com/p/0nSUzqtvWx/
Blazing up the esses https://instagram.com/p/0loX-tNvXs/
Then the transmission exploded again
Element Tuning is offline   Reply With Quote
The Following 6 Users Say Thank You to Element Tuning For This Useful Post:
DAEMANO (03-25-2015), keen as (03-26-2015), MINOCIN (03-26-2015), Raven604 (03-25-2015), Rosticles (03-25-2015), Ultramaroon (03-25-2015)
Old 03-24-2015, 10:48 PM   #382
gramicci101
Off Topic
Do you just keep spares on hand now so you can swap them at the track?
Old 03-25-2015, 01:05 AM   #383
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You totally failed to extend your middle finger while passing that Z06. I am disappointed. I'm also beginning to think it's time to invest in a Hollinger or something.
Old 03-25-2015, 01:45 AM   #384
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Sitting in traffic by 25°C, coolant will reach 100°C easy peasy. Unless the A/C is on.
Guillaume is offline   Reply With Quote
Old 03-25-2015, 02:19 AM   #385
Element Tuning
While we're aren't racing with crazy power I think I'm way more abusive than most given the heat, extended wot running, and curb hopping. Serious lube and a cooler is your best friend!
Yes I'm going to have to bring a spare transmission to each major race if I choose to race at 400 hp or less. More than that will require a different gearbox.
Old 03-25-2015, 02:51 AM   #386
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I smell Hollinger....maybe PPG? Everyone loves a good throw-your-head-back-for-some-whiplash-dogboxes
Old 03-25-2015, 04:25 AM   #387
sam69
Drives: GT 86
Have you thought about getting the gearbox cryoed to see if that would make it strong enough ??
sam69 is offline   Reply With Quote
Old 03-25-2015, 06:13 AM   #388
AJPG
Drives: 22RE, FA20, 4G63
Nice indeed!
So sorry for the gearbox misfortune. Out of curiosity, each time that break is the same or it fails at different things?
AJPG is offline   Reply With Quote
Old 03-25-2015, 11:20 AM   #389
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Time for some experimenting to make the stock gearbox stronger, like a new stronger tooth pattern for fourth gear and carbon syncros.
Darryljr11 is offline   Reply With Quote
Old 03-25-2015, 12:23 PM   #390
Element Tuning
Yeah it's almost always the same set of difficulties, power, and how I drive. As mentioned a pump, cooler, and butch fluid goes a long way under track conditions. Cushioning and lubrication to the gears is super important to reducing stress and heat.
What happens is that I start missing shifts due to a "sticky" shift feeling into 4th and usually 6th. Then it usually breaks when I pull the trigger on a fast lap as I'm usually crashing the curbs and catching air.
At this point a really expensive gearbox doesn't make much sense as the engines oil pressure is right at limit along with the gearbox. I feel we need to lick the oil pressure issue first so we can race at 450-500 HP.
John Hotchkis and one of his engineers took a liking to our FRS at VIR and we chatted a long time about oiling etc as he worked on a NASCAR team. A lot of what he said also jives with the engineers at Joe Gibbs who talked to me at the UTCC race. The bottom line is oil volume and cooling. Given our Pro Comp engine can deliver enough oil pressure when temps are in control I'm inclined to follow their lead but not sure I can run 6 gallons of oil and an oil cooler the size of my radiator.
I might hit Perrin up to either supply a "race" size oil cooler or even double up on what we have from them.
The Following 4 Users Say Thank You to Element Tuning For This Useful Post:
keen as (03-26-2015), Koa (03-27-2015), MINOCIN (03-26-2015), Ultramaroon (03-25-2015)
Old 03-27-2015, 02:27 AM   #391
D K
Stig's dark passenger
There is a much cheaper trans alternative on the horizon.
Just be patient guys.
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
BRZGM3 (03-27-2015)
Old 03-27-2015, 02:35 AM   #392
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Other than the front of the car, where else would you put an oil cooler that size? I mean at this point do you need headlights because that could free you up some airflow... Off the top of my head I'm thinking under the car? But I dont think it would get enough air to pass over it, plus rocks and debris...
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
