Old 03-18-2015, 06:27 AM   #1
RelentlessGT
Drives: Toyota GT86 Manual
Ceramic Coated Headers
Hi everyone,
I am paranoid about excessive engine temperatures for my daily driver/occasional track day car and I have done the DIY OEM Forester sandwich-style oil cooler with good results (up to 12 deg. celcius cooler).
I am now looking at unequal length headers to remove the horrible torque dip and for a little bit more power output (combined with an OFT and maybe E85). In Australia we can get Ceramic Coated Prospeed Racing UEL Headers (aka. SSI) for $950 or non-coated for $700. These are very similar to Tomei (same factory).
Does anyone have any objective evidence of reduced engine temperatures on the track to show the heat benefits of ceramic coated headers over uncoated stainless steel ones?
RelentlessGT is offline   Reply With Quote
The Following User Says Thank You to RelentlessGT For This Useful Post:
JDM4E (11-02-2016)
Old 03-18-2015, 06:58 AM   #2
steve99
Drives: FT86
Originally Posted by RelentlessGT View Post
Hi everyone,
Talk to @Wayno or @s2d4 both have coated header in oz
Old 03-18-2015, 07:14 AM   #3
WesleyG
Drives: 2014 Satin White Pearl GTS auto
I have ceramic coated headers in my other car, and they make a big difference with engine bay temperatures
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 03-18-2015, 11:19 AM   #4
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Data!
http://www.ft86club.com/forums/showthread.php?p=2010555
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following 2 Users Say Thank You to phobos512 For This Useful Post:
DocWalt (03-20-2015), Hyper4mance2k (03-19-2015)
Old 03-18-2015, 02:47 PM   #5
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I have a top speed ceramic coated header and love it.
Lunatic is offline   Reply With Quote
Old 03-18-2015, 04:27 PM   #6
Tbird232ci
Drives: 2013 FRS
I've run ceramic coated headers on my Trans Am and there was a significant drop in engine bay temp. The issue I ran into was that they were mild steel once the coating flaked, they rusted out and broke off.
I like ceramic coating much better than heat wrap.
Tbird232ci is offline   Reply With Quote
Old 03-18-2015, 09:32 PM   #7
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
On the track or any time you're at speed it won't make a much of a difference because air is forced in the front air dam, past the engine and mostly out the transmission tunnel with some going out past the steering arms and overpipe. The problem is at idle everything in the compartment heat soaks immediately because the upper half of the engine bay is sealed.
The other problem is uncoated headers radiate heat directly at head gaskets, front engine cover gasket, thermostat gasket, gasket sealant, etc so down the road you or the unsuspecting next owner has to tear the whole engine out to replace those. Uncoated catted headers would be the worse.
When you get OFT or custom tune, regardless of what headers you have, adjust your radiator fans to come on at idle, so you avoid unnecessarily heat soaking everything in the engine bay by an extra 20C.
http://www.ft86club.com/forums/showthread.php?t=64731
Tomei is a cleaner install, at an extra cost of about $300 and a couple days back and forward to coaters (850 + 150 OP + 250 coating).
PSR:
Old 03-19-2015, 01:00 AM   #8
RacerX
Drives: Subaru BRZ
PSR:
Thats a good idea.
RacerX is offline   Reply With Quote
Old 03-19-2015, 02:56 AM   #9
RelentlessGT
Thanks everyone.
It sounds like the ceramic coating is worthwhile. I understand the point about air movement at speed but I still can't help but think there should be a _minor_ gain from these on the track but I guess that is up to measurements to prove.
@Wayno:
I already have the Stage 1 tune and am going to Philip Island next week (so not time for headers this week). I will look into your fan activation mod as currently as soon as I stop pushing (cooldown lap) I turn on aircon to force the fans to activate. The cooldown lop is where the Oil Cooler is very noticeable as the oil temperature drops much quicker than prior.
Old 03-19-2015, 03:10 AM   #10
Wayno
Wayno's Avatar
I would say if you're going to so less than 200km between flashing and tracking, hold off flashing until after the track. You want your fuel trims to be well and truly dialed in beforehand.
Old 03-19-2015, 07:07 AM   #11
ZZT86
ZZT86's Avatar
Drives: BR86
Highly recommend, header so cool you can touch it after the drive. Amazing.
ZZT86 is offline   Reply With Quote
Old 03-19-2015, 08:16 AM   #12
Bergen23
Drives: '15 Halo FR-S
Would applying a VHT paint be similar? Like, I could do it at home in my garage kind of thing?
Bergen23 is offline   Reply With Quote
Old 03-19-2015, 09:02 AM   #13
OkieSnuffBox
Drives: '23 BRZ Limited
Nope, not even close.
Old 03-19-2015, 12:18 PM   #14
FISHBURGLAR
Drives: whiteout fr-s
I ordered my OFT + OFH last week! i have one questions though. I live in NY as you know we get bad winters and salt, plus we get HOT days sitting in traffic. I was wondering if I should ceramic coat these headers. If i should, any suggestions where to send them?
FISHBURGLAR is offline   Reply With Quote
Ceramic Coated Ptuning Headers Ambient Temperature Testing s30series Engine, Exhaust, Transmission 32 03-17-2016 02:58 PM
Jdl ceramic coated downpipe. never mounted Shit Luck Engine, Exhaust, Bolt-Ons 5 04-13-2015 12:04 PM
FS Ceramic Coated Nameless ELH Brinks Engine, Exhaust, Bolt-Ons 2 08-09-2014 03:16 PM
header bare, wrapped, or ceramic coated? lbroskee Engine, Exhaust, Transmission 18 01-21-2014 11:48 AM
Takeda Exhaust ceramic coated FR-Shadow Engine, Exhaust, Bolt-Ons 6 11-12-2013 09:29 PM
