View Poll Results: bare, wrapped, ceramic coated?
bare 30 24.79%
wrapped 22 18.18%
ceramic coated 69 57.02%
Voters: 121. You may not vote on this poll
Old 05-12-2013, 07:25 PM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
header bare, wrapped, or ceramic coated?
im ordering my headers soon and ceramic coating is a $150 option, but im not sure what the best route to go is.
do i order them bare?
do i order them bare then wrap them?
do i order them ceramic coated?
they are the FA20CLUB headers so they will be used with the full header kit down the line.
along with any other good info i can get on this, @lexusb3, what did you do for yours?
lbroskee is offline   Reply With Quote
Old 05-12-2013, 07:30 PM   #2
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
If you have the cash i'd ceramic coat them...that's what i plan on doing. Helps under hood temps and keeps rust away longer.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-12-2013, 07:32 PM   #3
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Bare or Ceramic coated..
http://www.ft86club.com/forums/showp...&postcount=143
Some people have had oil/brake fluid leak on to wraps, and then catch on fire.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 05-12-2013, 07:38 PM   #4
mrk1
Drives: Sterling BRZ Ltd
i vote ceramic, however not all ceramic is the same. I had some sti parts done with jet hots basic level coating and it chipped with the slightest scrap during installation. It worked but I was pretty disappointed about the durability.
Swain Tech makes a white lightening coating and that stuff is thick and I've heard nothing but good things about it, just get over the fact that it only comes in white.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-12-2013, 07:40 PM   #5
wparsons
wparsons's Avatar
Bare or ceramic, don't wrap them!
flickr
Old 05-12-2013, 07:40 PM   #6
lbroskee
lbroskee's Avatar
options are black and silver, but ill def be going black
Old 05-12-2013, 07:49 PM   #7
lexusb3
Drives: FRS
I wrapped mine ... I push my car hard and when i pull up to work I can touch it and its nice and warm IMO its working fine for me everyone will have somthing different to say but i dont have one problem
lexusb3 is offline   Reply With Quote
Old 05-12-2013, 07:49 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
There's a joke in there somewhere, I'm sure of it.
Wraps are also famous for holding water and causing a header to rust faster then if left bare.
Old 05-13-2013, 01:56 AM   #9
reeves
Got the bare option.. I like the cool looking goldish color it becomes after it's been used for the first time.
reeves is offline   Reply With Quote
Old 05-13-2013, 10:45 AM   #10
wparsons
wparsons's Avatar
This. On a race car it's not such a big deal since it probably never stays wet, but on a street car it'll hold moisture and corrode the headers much faster.
flickr
Old 05-16-2013, 08:14 AM   #11
mad_sb
These days there are hard drying silicone coatings you spray over the wrap after the intial drying... makes the wrap feel like a hard cast. These prevent (or significantly reduce) water absorption. I wrapped the whole exhaust (downpipe to muffler) on my evo viii, did the spray coating, never had any moisture or corrosion issues over the course of 4 or 5 years... then again, i am in georgia and we do not have salt related corrosion issues here so...
I will be wrapping and sealing mine, if nameless ever releases theirs that is
Old 05-16-2013, 08:38 AM   #12
ft_sjo
Drives: GT86
I've seen wrapped manifolds catch fire with simple oil spills before and there's not much you can do to stop it as the oil is embedded in the wrap. You end up having to take it all off anyway.
Old 05-16-2013, 09:41 AM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
I think that was the point of the silicon sealant that @mad_sb was referring to, it creates a barrier between the wrap itself and any fluid that may drip onto it.
Old 05-16-2013, 02:52 PM   #14
mad_sb
Yup, you do have to be carefull when working with oil etc around the wraps, but it's easy enough to cover the wrap when you changing oil etc.
I may put heat barrier on the oil pan and just wrap the section the turns up in front of the motor.... but I have plenty of time to change my mind a few times before nameless will be ready to ship.
Motiv Concepts Ceramic Coated Overpipe Group Buy! MotivConcepts Groupbuys 7 06-03-2013 01:50 AM
Motiv Concepts Ceramic Coated Overpipe Group Buy! MotivConcepts Engine, Exhaust, Bolt-Ons 0 04-05-2013 02:52 PM
Motiv Concepts Ceramic Coated Overpipe Group Buy? MotivConcepts Engine, Exhaust, Bolt-Ons 2 03-20-2013 06:53 PM
The bare minimum? Scaldy Scion FR-S / Toyota 86 GT86 General Forum 8 06-11-2012 09:58 AM
New Zealand bare-bones spec 86 bricktop AUSTRALIA 3 01-13-2012 08:02 PM
