Old 03-16-2015, 10:40 PM   #15
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by cawith View Post
I have had the same issue and I'd also done the IPW changes.
Don't know what the popping is, but it doesn't sound very good. Found out that if I revved it to 2500-3000 rpm just once immediately after the engine had turned on, then the popping would not happen. Have you tried that?
It's just misfire - fuel doesn't ignite consistently at first when everything is cold. Fuel buildup can cause it to ignite back into the intake manifold. In your case it's pretty harmless, it should last only a short while and backfires are minimal, just let it idle it out. In other cases it can be a problem - first thing that comes to mind is the early 80's porsche 911 SC with the CIS fuel injection systems. Intake backfire would split open the airbox!
Old 03-16-2015, 11:24 PM   #16
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I strongly enriched several start tables and got first-try starts on e85 at 50F. This is with Propel, which has a high ethanol content. A gallon or two of 91 will also go a long, long way towards easing starts. If you go from a near-empty tank of 91 and then fill it with ethanol, you'll start just great because of that gallon of gas sloshing around. Run it low again and fill up with e85, however, and without that extra gas, the hard starts begin.
Old 03-17-2015, 04:42 PM   #17
Akari
Drives: 2013 DGM BRZ
With true E85 I had problems starting below 50 degrees with a unaltered OFT Stage 2 E85 tune.
Akari is offline   Reply With Quote
Old 03-17-2015, 08:24 PM   #18
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Someone will have to define "hard start". To me that means it doesn't start on the first crank. To someone else that might mean it starts after 5 or 10.
Old 03-19-2015, 08:15 AM   #19
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Mine's a SmartKey so I go by if it starts on the first button press or if I have to shut it off and try again; havent had to do that since making the IPW changes
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Coldest you've driven your BRZ Deslock BRZ First-Gen (2012+) — General Topics 18 02-18-2015 06:07 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
