Old 03-07-2015, 09:34 PM   #15
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Originally Posted by dwx View Post
They are probably the weakest part of the heads, it's the first thing people replace. I can't see doing new valves without doing new springs, it makes no sense.
Does your car run okay, stumble at all? When the AVCS system on the WRX/STi acts up in similar manners the car runs like crap.
Car runs fine for now. But how do you explain this?
texasbound972 is offline   Reply With Quote
Old 03-07-2015, 09:42 PM   #16
steve99
Drives: FT86
crankcase breather catch can ?
coolant in oil.
what does the oil filler cap look like ?
lost any coolant
Old 03-07-2015, 10:51 PM   #17
texasbound972
USMC
coolant in oil.
lost any coolant
This is the can on the drivers side coming from under the ac compressor to the can back to the intake. Coolant is always disappearing in these cars. There is no moisture under the oil cap.
Old 03-07-2015, 11:23 PM   #18
wootwoot
Drives: FRS
Holy shit....
Old 03-08-2015, 03:08 AM   #19
sw20kosh
Drives: 2013 Black FR-S
...this has to be a joke? That literally looks like lotion or something else that is three letters and starts with a "c".
Could it be assembly lube?
@CSG Mike
Old 03-08-2015, 09:22 AM   #20
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
That's what I bought a catch can for..... Brazzers.
2016 Camaro SS is offline   Reply With Quote
Old 03-08-2015, 11:38 AM   #21
texasbound972
USMC
I had been having issues with the car stalling on startup after the built engine was installed and it just kept getting worst. I had sent logs to bill at delicious tuning and he sent me back an updated tune. My fear is that the two tunes he sent me he might of kept adding more fuel below a certain rpm. During this time I was running Crawfords air oil separator (AOS) which returns the oil back to the engine. Not a good thing to do when it's fuel getting dumped in the engine. Thank god I decided to get the Radium dual catch can setup!
found this just before the dyno.
Here is the results. Blue is the first dyno I did when the turbo was first installed on the stock block.
Old 03-08-2015, 03:25 PM   #22
stugray
Drives: 2013 GBS BRZ Limited
No built heads and stock cams. Yes they are stock valve springs lol. They seem to work fine in the Crawford BRZ so Quirt didn't see a need to change them out.
It has been a while since I watched the video about the Crawford BRZ.
But in that story, they explain that they take the whole engine apart to inspect the components and when they reassemble it the ONLY parts they upgraded were the valve springs...
Or maybe we are talking about a different "Crawford BRZ"?
Old 03-08-2015, 04:29 PM   #23
Dipstik-sportech
Dipstik-sportech's Avatar
Well there's $12k you'll never get back. Who puts cams and ported heads with stock valve springs?!
Old 03-08-2015, 08:48 PM   #24
xwd
coolant in oil.
lost any coolant
Most people get white sludge because it's oil mixing with condensing water due to colder weather. Crawford made a second revision of their WRX/STi AOS to circulate coolant through the can to keep the temperature high enough that wouldn't happen, because the V1 was dumping sludge back into the engine. If you are getting enough blowby and enough water somehow you'd end up with that.
Old 03-08-2015, 11:08 PM   #25
stugray
This might sound stupid, but have you checked your oil pressure?
Old 03-09-2015, 12:10 AM   #26
texasbound972
USMC
No I haven't.
Old 05-08-2015, 02:59 PM   #27
Astroboy
Astroboy's Avatar
Drives: None
So the other day my SLOFRS was on the dyno and Bill from Delicious Tuning couldn't get more power out of her. Supposedly the cams weren't opening the valves enough and there wasn't a code either. On my way to work I scanned the car with the torque app and P0018 powertrain popped up. I have a newly built engine from Crawford Performance. Has anybody had this problem?
Can you check on the torque app if they are running or not? I'm interested if you can. If you can, let me know how please!
Astroboy is offline   Reply With Quote
Old 05-08-2015, 03:26 PM   #28
wparsons
wparsons's Avatar
What's the boost target on both runs? What's the c/r on the new block? If you've dropped a couple points you're going to need a lot more boost to make the same power you were before.
flickr
Cams Fabron757 Forced Induction 10 01-13-2015 06:30 PM
HKS cams JesseTheFlash Engine, Exhaust, Transmission 4 01-09-2015 07:42 PM
Wtb oem cams midnight23 Want-To-Buy Requests 0 03-19-2014 12:07 PM
Cams? Sonolin Engine, Exhaust, Transmission 10 05-21-2013 10:49 PM
Cams Surok Engine, Exhaust, Transmission 10 01-01-2013 08:30 PM
