Old 01-09-2015, 01:11 PM   #1
JesseTheFlash
JesseTheFlash's Avatar
Drives: 2013 Scion FRS
HKS cams
does anyone have more info about them? and is it worth getting on a N/A car?
JesseTheFlash is offline   Reply With Quote
Old 01-09-2015, 01:24 PM   #2
mid_life_crisis
Drives: FR-S 10 #103 AT
According to a thread by one of the sponsors, the cams are fine. The weakness is that the heads are restrictive and need to be worked.
Old 01-09-2015, 03:08 PM   #3
JesseTheFlash
mmm I see, so it's not worth buying..yet?
Old 01-09-2015, 03:20 PM   #4
mid_life_crisis
I think I'd wait and see what the professionals experience first.
Old 01-09-2015, 07:42 PM   #5
xwd
They only work if you buy the HKS stroker kit. They put recesses in the stroker kit pistons for the added lift. If you put the cams in an otherwise stock motor bad things would happen. The FA20 just has very little piston to valve clearance.
P0230 and...cams? Reaper Software Tuning 1 06-01-2014 05:51 PM
Wtb oem cams midnight23 Want-To-Buy Requests 0 03-19-2014 12:07 PM
Aftermarket Cams usptwins Engine, Exhaust, Transmission 20 08-03-2013 07:54 PM
Cams? Sonolin Engine, Exhaust, Transmission 10 05-21-2013 10:49 PM
Cams Surok Engine, Exhaust, Transmission 10 01-01-2013 08:30 PM
