Old 03-06-2015, 09:49 AM   #1
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Cams not working.
So the other day my SLOFRS was on the dyno and Bill from Delicious Tuning couldn't get more power out of her. Supposedly the cams weren't opening the valves enough and there wasn't a code either. On my way to work I scanned the car with the torque app and P0018 powertrain popped up. I have a newly built engine from Crawford Performance. Has anybody had this problem?
texasbound972 is offline   Reply With Quote
Old 03-06-2015, 12:51 PM   #2
Dipstik-sportech
Dipstik-sportech's Avatar
You answered your own question, Crawford performance built engine.
Old 03-06-2015, 01:12 PM   #3
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
On a more serious note. Will be interesting to see the outcome...
Old 03-06-2015, 02:14 PM   #4
OkieSnuffBox
Drives: '23 BRZ Limited
I don't understand, the valves/cams are mechanical, not pneumatic or like the Fiat AIR engine.
I can see not being able to adjust the TIMING of the cams being a problem.
Old 03-06-2015, 05:14 PM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
whats wrong with Crawford ? I know they are reputable ?
Old 03-06-2015, 05:19 PM   #6
Dipstik-sportech
Many many things. If the vvti isn't working it's 100% an assembly problem. Either the assembly wasn't installed correctly or maybe they broke the solenoids installing the engine. Usually the vvti issue with these cars affects one, maybe two cams but not all four. Crawford's amazing build quality lol, how quick is the catch can filling up?
Old 03-06-2015, 05:36 PM   #7
stugray
Drives: 2013 GBS BRZ Limited
Wait.... WHAT??!?
So crawford offers variable valve lift options?
Old 03-06-2015, 05:51 PM   #8
Dipstik-sportech
Yeah didn't you hear they made VTEC for the fa20?! Am I to understand you have built heads and cams but stock springs....???
Old 03-07-2015, 11:28 AM   #9
xwd
Would probably be more helpful if Bill was in this thread. Is the VVTI working at all? You said it's not opening the valve enough, does that mean not opening it enough given the VVTI advance? P0018 is the only code?
With other Subarus this is a crappy one to diagnose. There are a few options:
1) Timing chain isn't correct
2) Oil issues are causing VVTI to not actuate correctly, do you have an oil pressure gauge?
3) Bad oil control valve, my guess since it's happened to others
4) Bad sensor or bad wiring. Check the plugs to those sensors.
Old 03-07-2015, 11:44 AM   #10
mrk1
Drives: Sterling BRZ Ltd
Have you contacted Crawford about the issue? Posting this here is just going to turn into an internet game of whisper down the lane. Soon enough this single experience will turn into "Your cams wont work if Crawford builds your motor"
To me it sounds like something is off with the variable cam timing. Something small enough that the engine still runs fine but just not at full potential. If your having this issue right off the bat after getting your engine built it should be no contest to have Crawford investigate. Did Crawford build and install?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-07-2015, 11:50 AM   #11
texasbound972
USMC
I have contacted Crawford. Was waiting to hear from the man lol. I need to first get in there and clean the sensors out and go from there. Just wondered if this has happened to anyone else.
Old 03-07-2015, 11:53 AM   #12
texasbound972
USMC
The new catch cans were filling up pretty quick. I've even spotted some white almost lotion consistency from the driver side catch can. Pulled the can right before the last dyno and there was a good amount of fuel in them.
Old 03-07-2015, 11:55 AM   #13
texasbound972
USMC
No built heads and stock cams. Yes they are stock valve springs lol. They seem to work fine in the Crawford BRZ so Quirt didn't see a need to change them out.
Old 03-07-2015, 06:33 PM   #14
xwd
They are probably the weakest part of the heads, it's the first thing people replace. I can't see doing new valves without doing new springs, it makes no sense.
Does your car run okay, stumble at all? When the AVCS system on the WRX/STi acts up in similar manners the car runs like crap.
Cams Fabron757 Forced Induction 10 01-13-2015 06:30 PM
HKS cams JesseTheFlash Engine, Exhaust, Transmission 4 01-09-2015 07:42 PM
Wtb oem cams midnight23 Want-To-Buy Requests 0 03-19-2014 12:07 PM
Cams? Sonolin Engine, Exhaust, Transmission 10 05-21-2013 10:49 PM
Cams Surok Engine, Exhaust, Transmission 10 01-01-2013 08:30 PM
