Old 02-27-2015, 03:14 PM   #211
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Just made the tweaks as outlined in this thread...
http://www.ft86club.com/forums/showp...1&postcount=40
waiting on an empty tank to fill back up with e85 and see how it works...
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 02-27-2015, 07:08 PM   #212
steve99
Drives: FT86
Originally Posted by GT86meMR2 View Post
So how much 98 should i add to 20L of E85? (Jerrycans)
Add about 10 to 15% to assist cold start so for 20 literes E85 add 2 to 3 litres petrol.
Dont add much more petrol than that as your ethanol percent will get to low.
Old 02-27-2015, 07:12 PM   #213
steve99
Drives: FT86
Originally Posted by tracerit View Post
is there any damage from having a bad start?
Generally failed starts on ethanol fuel due ethanol has higher flash point than petrol and fails ro light up on cold start. if its starting on second or third attemp cannot see any big issue.
if your taking 6 cranks or something then yes might be additional wear on starter and fuel diluting oil issues.
add some petrol to your e85 or adjust cranking tables or both if its rearly cold.
tracerit (02-27-2015)
Old 02-27-2015, 07:14 PM   #214
steve99
Drives: FT86
Originally Posted by elBarto View Post
The easy way is to add some regular fuel with the E85, the other way is to tweak some settings in RomRaider, somewhere is a topic about this.
its in links below, in tune tweaks link and linked in E85 on stock car link
http://www.ft86club.com/forums/showthread.php?t=67310
Old 02-27-2015, 11:35 PM   #215
tracerit
Drives: '13 SSM BRZ Limited 6MT
This is more of a continuation from my other thread about having 10% LTFT after fueling up on E85. @steve99 mentioned the I probably got near true 85% ethanol in that fuel up, and a fix would be to add some regular gas/petrol. I did and it dropped to 7% ish.
My question is, if I keep adding more gas/petrol, will the LTFT keep dropping or is there a limit to how much gas/petrol I can add before it's unsafe?
tracerit is offline   Reply With Quote
Old 02-28-2015, 02:19 AM   #216
steve99
Drives: FT86
Shiv reckons the tune will cope with between E60 and E90 ie you would expect around -10% ltft on E60 and around +10% ltft on E90. Assuming everything else is ok like no intake exhaust leaks and your on stock intake.
If you not testing your E85 with a kit i would not add more than 5 litres (gallon or so) of petrol to a full tank
At around E70-75 your trims should low around 5% or or so.
If you have other issues like intake exhaust leaks you need to sort them first. If you have aftermarket intake then your going to need maf scaling done or the tune may not work for you and actually be dangerous.
If your seeing ltft well over 10% on pump E85 its likely you have other issues.
It can look like this, however I am lucky and we have guaranteed 85% e85 at pump
http://datazap.me/u/steve99/e85-maf-...zoom=5352-7356
tracerit (02-28-2015)
Old 03-03-2015, 09:20 PM   #217
momo3605
Drives: 2014 Fr-S Monogram
I just started having cranking issues, today was the first day car failed to start, yesterday it choked and started, so today I put 1 gallon of 91 in my tank. Has anyone gotten the car to start smoothly by mixing a gallon of gas? Also, is there any word of Shiv coming out with a fix for this? Or is this an issue that we have to live with?
momo3605 is offline   Reply With Quote
Old 03-03-2015, 09:56 PM   #218
steve99
Drives: FT86
have a look in the "tune tweaks" link below some info their on adjusting Crankng Injector Pulse widths to get it started easier in cold weather. Adding a gallon of petrol/gass will help as well.
direct link here
Old 03-05-2015, 08:24 AM   #219
Silver Ignition
APEXHNTR
direct link here
I did these tweaks and it started fine this morning...
#1867 of 2500
The Following User Says Thank You to Silver Ignition For This Useful Post:
momo3605 (03-05-2015)
Old 03-05-2015, 08:18 PM   #220
momo3605
Thanks for the input! I'll give it a try. Did you just copy the tables from the post?
Old 03-06-2015, 03:27 AM   #221
momo3605
Did you also zero out the IPW table? Seems like a drastic change, so I just want to make sure I won't blow my car up
Old 03-06-2015, 07:06 AM   #222
Trettiosjuan
Drives: GT86
I just copied them this monday, always needed to add 3l gas for it to start clean year round before. Refuelled yesterday without and running approx. E75 winterblend in 40 degree fahrenheit weather. It starts right away but after a few seconds I need to add throttle or it will die again. So seems to be working. If anything changes further on I'll report it here...
Trettiosjuan is offline   Reply With Quote
Old 03-06-2015, 08:12 AM   #223
Silver Ignition
APEXHNTR
started perfect again this morning at 23*F
yep copied exactly how he has it in the thread
#1867 of 2500
Old 03-06-2015, 03:49 PM   #224
momo3605
Made the changes on Malt's post, and it didn't work. Car still stalled first time. It was 70 degrees outside as well! What's wrong with my car!!
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
