#183 | |
Your list/cost is about dead on. The only difference is I'm kinda picky so I tend to custom make various things such as the passthru cable in order to avoid clearance issues and use only what the unit needs. I'll be able to hammer down a final on everything soon. Edit: And it's definitely not an ELM327 unit. |
#184 |
Drives: 2013 GBS BRZ Limited
#185 | |
If there is a particular app you are curious could achieve this, I'd be happy to take a look any give you my opinion. |
#186 | |
I have one of those too. |
#187 | |
EDIT: Just browsed the website. They are reflashing, I don't do any reflashing. At this moment I'm just targeting 1 system in the network so there isn't an advantage for reflashing yet. I have future ideas though that might have me on the reflashing path. Last edited by 86Nanny; 03-02-2015 at 05:44 PM. |
#188 | |
Bilge monkey
Drives: '13 BRZ, 82 starlet
#189 | |
They can also log data at high rate and make generic CAN Bus transactions. It is essentially an Arduino with the CAN bus shield (and then some) already in one package for ~$150 ea. |
#190 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
I think the Tactrix a more powerful microcontroller (but that is admittedly splitting hairs).
The ELM327 chips are ok for doing some OBD II transactions. Most of the better stuff is using scantool.net chips (STN1xxx). They accept all the AT commands like an ELM chip but also add some other features (for the very curious: http://www.scantool.net/scantool/dow..._vs_elm327.pdf) |
#191 |
Drives: MY15 86 GTS
| The Following User Says Thank You to mig86 For This Useful Post: | Hyper4mance2k (03-27-2015) |
#192 | |
Elite Recognized Geek
Drives: 2014 DGM BRZ Limited
It sounds like I could just unplug that device after the "pedal dance" mode is engaged, but I'm not sure that repeatedly fumbling with the 86's notoriously-flaky connector is really a great idea - plus I'm not sure that would actually be easier than doing the Pedal Dance the manual way. ![]() Not knocking it, just genuinely curious.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+ |
#193 |
Alexandrino_Auto
Drives: series.Blue
Ohhh competition... I can't wait to give you my hard earned money. This car is such a hindrance to my ability to feed myself!!!
The Shadetree Project: I turn wrenches
#194 |
Or you can just get an OFT and it is capable of the pedal dance mode now.
#195 |
Drives: MY15 86 GTS
You can buy a two way adaptor on ebay (y cable) for about $5. I would do this because the factory plug is not really robust and the you can tuck the device away (unclip the factory plug and secure behind the dash). Now you have a more robust, replacable plug for other items.
This will in no way interfere with other OBD devices, so keep your telemetry. No need to unplug, its set and forget. Can't see how that could be 'harder' than the manual way. |
| The Following User Says Thank You to mig86 For This Useful Post: | codesplice (03-27-2015) |
#196 | |
Drives: MY15 86 GTS
Still, great feature on the OFT for those with one. |
| The Following User Says Thank You to mig86 For This Useful Post: | stugray (03-28-2015) |
| brake override DOES NOT diminish heel & toe | 4agze | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 09-17-2012 04:43 AM |
| Permanent Optimum opti-coat 2.0 ?? | Ericfrs | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 4 | 09-04-2012 02:11 AM |
| LF: rear fog switch picture | Silverdub | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-28-2012 08:34 AM |
| Anyone going to switch badges? | DougieFresh | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 09-28-2011 02:56 AM |
| Brake override system in the FT-86? | mrKiKaZ | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 02-22-2010 11:33 AM |
