Old 03-01-2015, 02:08 PM   #183
86Nanny
So does yours get the same results as the pedal dance?
Or is it just the same as the VSC/TC buttons.
Convince me that it works by explaining it just a bit.
I see the bare minimum that it would take to build one (assuming all interfaces are on the ODBII connector):
Arduino - $35
OBD Shield - $50
OBD passthru cable - $25
Case and associated hardware - $10
So total in hardware costs = $125
UNLESS it can work from a Droid phone and an ELM327, then it is just $10.
@stugray Sure! I don't mind explaining. The unit does achieve the same results as the pedal dance and isn't just Trac/VSC disabled.
Your list/cost is about dead on. The only difference is I'm kinda picky so I tend to custom make various things such as the passthru cable in order to avoid clearance issues and use only what the unit needs. I'll be able to hammer down a final on everything soon.
Edit: And it's definitely not an ELM327 unit.
86Nanny is offline   Reply With Quote
Old 03-01-2015, 04:06 PM   #184
stugray
Drives: 2013 GBS BRZ Limited
But if the transactions are standard OBD, then the ELM327 should be able to execute those commands wouldnt it?
Old 03-01-2015, 04:41 PM   #185
86Nanny
@stugray Yes there are some tasks a ELM327 chip could accomplish, but without having a custom coded 327 chip to handle submit & response transactions, you'll run into plateaus. I haven't looked into the Android ELM327 apps you mentioned to know how deep you can go, but at a chip level I know there are going to be limitations. The biggest issue will be filtering for responses from the network so your device knows when to continue communication/stay in sync. Most 327 chips the buffer will fill up too quickly to get what you need in time. The nodes in these cars are quite noisy.
If there is a particular app you are curious could achieve this, I'd be happy to take a look any give you my opinion.
Old 03-02-2015, 04:58 PM   #186
stugray
Sounds like you are trying to build a Tactrix.
I have one of those too.
Old 03-02-2015, 05:34 PM   #187
86Nanny
I'm not familiar with Tactrix, but I'll look it up to see what the similarities are.
EDIT: Just browsed the website. They are reflashing, I don't do any reflashing. At this moment I'm just targeting 1 system in the network so there isn't an advantage for reflashing yet. I have future ideas though that might have me on the reflashing path.
Old 03-02-2015, 05:45 PM   #188
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
Originally Posted by Dustin View Post
Not trying to thrash on your idea here, but seriously people, it's 3 seconds. With all the time and effort involved to make this a functional kit, even if it took only 5 minutes to install and only cost $30 for the kit, depending on how much you make an hour, you could do the 3 second feature over 1000 times before you would see a return on your "investment".
worth every penny lol
Sammakko is offline   Reply With Quote
Old 03-02-2015, 06:02 PM   #189
stugray
They can do a lot more than flashing.
They can also log data at high rate and make generic CAN Bus transactions.
It is essentially an Arduino with the CAN bus shield (and then some) already in one package for ~$150 ea.
Old 03-02-2015, 06:59 PM   #190
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
I think the Tactrix a more powerful microcontroller (but that is admittedly splitting hairs).
The ELM327 chips are ok for doing some OBD II transactions. Most of the better stuff is using scantool.net chips (STN1xxx). They accept all the AT commands like an ELM chip but also add some other features (for the very curious: http://www.scantool.net/scantool/dow..._vs_elm327.pdf)
robot is offline   Reply With Quote
Old 03-27-2015, 01:25 AM   #191
mig86
Drives: MY15 86 GTS
http://www.ft86speedfactory.com/mig-...ator-2007.html
mig86 is offline   Reply With Quote
Old 03-27-2015, 09:25 AM   #192
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
Originally Posted by mig86 View Post
Any chance of a model which incorporates an OBD pass-through, so that I could still run OBD-based telemetry stuffs?
It sounds like I could just unplug that device after the "pedal dance" mode is engaged, but I'm not sure that repeatedly fumbling with the 86's notoriously-flaky connector is really a great idea - plus I'm not sure that would actually be easier than doing the Pedal Dance the manual way.
Not knocking it, just genuinely curious.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 03-27-2015, 01:06 PM   #193
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Ohhh competition... I can't wait to give you my hard earned money. This car is such a hindrance to my ability to feed myself!!!
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 03-27-2015, 01:45 PM   #194
stugray
Or you can just get an OFT and it is capable of the pedal dance mode now.
Old 03-27-2015, 04:29 PM   #195
mig86
Drives: MY15 86 GTS
You can buy a two way adaptor on ebay (y cable) for about $5. I would do this because the factory plug is not really robust and the you can tuck the device away (unclip the factory plug and secure behind the dash). Now you have a more robust, replacable plug for other items.
This will in no way interfere with other OBD devices, so keep your telemetry.
No need to unplug, its set and forget. Can't see how that could be 'harder' than the manual way.
Old 03-28-2015, 06:47 PM   #196
mig86
Drives: MY15 86 GTS
Yes, difference is that this requires no user input, automatically enter the mode each time the ign is cycles. Also does not need full warm up, just idle drop back.
Still, great feature on the OFT for those with one.
brake override DOES NOT diminish heel & toe 4agze Scion FR-S / Toyota 86 GT86 General Forum 31 09-17-2012 04:43 AM
Permanent Optimum opti-coat 2.0 ?? Ericfrs Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 09-04-2012 02:11 AM
LF: rear fog switch picture Silverdub Scion FR-S / Toyota 86 GT86 General Forum 6 06-28-2012 08:34 AM
Anyone going to switch badges? DougieFresh Scion FR-S / Toyota 86 GT86 General Forum 60 09-28-2011 02:56 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
