Old 02-21-2015, 10:30 PM   #1
jflogerzi
jflogerzi's Avatar
Best Jerrycan that fits into our trunks
I want to start running E85 @ track days but I know I am gonna need a good amount and would rather not pay the high prices at tracks. I am thinking between 8-10 Gallons should be enough bare in mind I can arrive at the track with about 1/3 to 1/2 haft of a tank.
Thoughts...
Old 02-21-2015, 11:36 PM   #2
swarb
People easily burn through 3/4 to full tank of regular, and e85 gets about 25% less mileage, so I would say you would need closer to 15 gallons. More is better so you can make it home too.
Old 02-22-2015, 12:28 AM   #3
Jonsey
Jonsey's Avatar
I run E85 at the track regularly. Some food for thought:
- I arrive at the track with 3/4 of a tank and bring 12g with me. I will run 4-20 minute sessions and arrive home between 3/8 and 1/4 of a tank using the 12g I brought
- If you have long, high g left handed sweepers, you can/will fuel starve below 5/8th of a tank. On the track i run when we are going ccw, I will fuel starve by the end of a session if I go out with less than 7/8 of a tank. It only happens on two corners, but it is really annoying when it happens
If I were you and you have the possibility of fuel starving based on the track, I would try to bring out 4-5 cans with you based on your low fuel level upon arriving at the track. I use VP fuel cans that each hold 6 gallons. I bought one hose for the can top and switch it out between jugs.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following User Says Thank You to Jonsey For This Useful Post:
Tristor (08-01-2018)
Old 02-22-2015, 01:05 AM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Unless you're taking a shit load of e85 to the track, just use gas. I've run into the fuel cut on e85. It's real. It sucks. It ruins your day.
Old 02-22-2015, 02:52 AM   #5
jflogerzi
jflogerzi's Avatar
fuel cut? You mean starvation?
Old 02-22-2015, 02:53 AM   #6
jflogerzi
jflogerzi's Avatar
Is this can you use?
[ame="http://www.amazon.com/VP-Racing-Fuel-3532-Blue/dp/B0006PJJC4/ref=pd_sbs_auto_3?ie=UTF8&refRID=06KW1FN43HPPCZAMP 0N9"]Amazon.com: VP Racing Fuel 3532 Blue Fuel Jug: Automotive[/ame]
If so does it fir in the trunk?
Old 02-22-2015, 04:26 AM   #7
mkivsoopra
You can fit 4 of those in the trunk if you're comfortable with laying them on their side. Otherwise, you can fit 5 of the regular 5-gal red jugs in the trunk (standing up) from the local auto parts store.
I burn through about 1/4 tank of e85 per 20 min session, but I'm FI.
mkivsoopra is offline   Reply With Quote
Old 02-22-2015, 04:48 PM   #8
Jonsey
Jonsey's Avatar
Those are the ones I use. As mentioned, I lay them on their side, just don't forget to tighten the air vent before laying them down.
Old 02-22-2015, 09:33 PM   #9
dave-
Drives: 86 GT
The correct answer is ANY.....
6x 20L jerry's. The yellow and outer red ones are low/wide and will actually fit with the non spare wheel carpet/plastic mat still fitted.
dave- is offline   Reply With Quote
Old 02-22-2015, 11:33 PM   #10
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Thoughts...
For streets of willow I am able to fill up at santa clarita and arrive with a bit over 3/4 and bring two 5 gallon vp racing jugs, I put them in the back seats with seat belts. For buttonwillow i will bring 3 5 gallons, 2 in back seat and one passenger..
I ended up using all 10 gallons at streets which meant I was able to leave with almost a full tank at the end of the day and I ran every session for the full amount of time allowed.
Build Thread
Instagram
The Following User Says Thank You to midnight23 For This Useful Post:
DAEMANO (02-22-2015)
Old 05-10-2015, 03:10 PM   #11
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Great thread!! I am planning on driving to Dallas from hemet, CA and was thinking about getting some kind of external fuel cell or I guess gas cans lol. E85 goes pretty quick and there just isn't enough stations on the trip to Texas.
texasbound972 is offline   Reply With Quote
Old 06-28-2018, 10:03 PM   #12
subi8612stpr
Drives: 2013 Black Subaru BRZ Limited
Bringing back a thread from the dead. In case anyone is figuring out to fit VP racing jugs in a 86 for track days and like me you’re not comfortable laying them on their side. You can fit 4 upright 5 gallon jugs, with the backseat folded down and then a bungee cord around them to keep them from moving.
subi8612stpr is offline   Reply With Quote
Old 06-29-2018, 11:06 AM   #13
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Jerry Cans work and they don't care which way you lay them. You can runs these over and they won't leak.
https://deutscheoptik.com/20-liter-j...t-of-four.html
Trueweltall is offline   Reply With Quote
The Following 2 Users Say Thank You to Trueweltall For This Useful Post:
new2subaru (06-29-2018), Tristor (08-01-2018)
WTT Trunks RWDDan Exterior Parts (Aero, Lighting, Etc.) 5 08-01-2014 01:35 PM
Any more trunks coming out? enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 9 06-29-2013 02:14 PM
Any one in NC/SC/VA or around want to trade trunks Hops Normal Southeast 0 12-30-2012 03:24 PM
WTT WRB Trunks in MA TONY_BRZ Exterior Parts (Aero, Lighting, Etc.) 2 12-08-2012 09:02 AM
Anyone in CO want to trade trunks? huma Exterior Parts (Aero, Lighting, Etc.) 11 08-01-2012 10:44 PM
