-   Tracking / Autocross / HPDE / Drifting (https://www.ft86club.com/forums/forumdisplay.php?f=39)
-   -   Best Jerrycan that fits into our trunks (https://www.ft86club.com/forums/showthread.php?t=82821)
jflogerzi 02-21-2015 10:30 PM
I want to start running E85 @ track days but I know I am gonna need a good amount and would rather not pay the high prices at tracks. I am thinking between 8-10 Gallons should be enough bare in mind I can arrive at the track with about 1/3 to 1/2 haft of a tank.
Thoughts...
swarb 02-21-2015 11:36 PM
People easily burn through 3/4 to full tank of regular, and e85 gets about 25% less mileage, so I would say you would need closer to 15 gallons. More is better so you can make it home too.
Jonsey 02-22-2015 12:28 AM
I run E85 at the track regularly. Some food for thought:
- I arrive at the track with 3/4 of a tank and bring 12g with me. I will run 4-20 minute sessions and arrive home between 3/8 and 1/4 of a tank using the 12g I brought
- If you have long, high g left handed sweepers, you can/will fuel starve below 5/8th of a tank. On the track i run when we are going ccw, I will fuel starve by the end of a session if I go out with less than 7/8 of a tank. It only happens on two corners, but it is really annoying when it happens
If I were you and you have the possibility of fuel starving based on the track, I would try to bring out 4-5 cans with you based on your low fuel level upon arriving at the track. I use VP fuel cans that each hold 6 gallons. I bought one hose for the can top and switch it out between jugs.
EAGLE5 02-22-2015 01:05 AM
Unless you're taking a shit load of e85 to the track, just use gas. I've run into the fuel cut on e85. It's real. It sucks. It ruins your day.
jflogerzi 02-22-2015 02:52 AM
fuel cut? You mean starvation?
jflogerzi 02-22-2015 02:53 AM
Is this can you use?
[ame="http://www.amazon.com/VP-Racing-Fuel-3532-Blue/dp/B0006PJJC4/ref=pd_sbs_auto_3?ie=UTF8&refRID=06KW1FN43HPPCZAMP 0N9"]Amazon.com: VP Racing Fuel 3532 Blue Fuel Jug: Automotive[/ame]
If so does it fir in the trunk?
mkivsoopra 02-22-2015 04:26 AM
You can fit 4 of those in the trunk if you're comfortable with laying them on their side. Otherwise, you can fit 5 of the regular 5-gal red jugs in the trunk (standing up) from the local auto parts store.
I burn through about 1/4 tank of e85 per 20 min session, but I'm FI.
Jonsey 02-22-2015 04:48 PM
Those are the ones I use. As mentioned, I lay them on their side, just don't forget to tighten the air vent before laying them down.
dave- 02-22-2015 09:33 PM
The correct answer is ANY.....
6x 20L jerry's. The yellow and outer red ones are low/wide and will actually fit with the non spare wheel carpet/plastic mat still fitted.
http://www.ft86club.com/forums/attac...1&d=1424658683
midnight23 02-22-2015 11:33 PM
Thoughts...
For streets of willow I am able to fill up at santa clarita and arrive with a bit over 3/4 and bring two 5 gallon vp racing jugs, I put them in the back seats with seat belts. For buttonwillow i will bring 3 5 gallons, 2 in back seat and one passenger..
I ended up using all 10 gallons at streets which meant I was able to leave with almost a full tank at the end of the day and I ran every session for the full amount of time allowed.
texasbound972 05-10-2015 03:10 PM
Great thread!! I am planning on driving to Dallas from hemet, CA and was thinking about getting some kind of external fuel cell or I guess gas cans lol. E85 goes pretty quick and there just isn't enough stations on the trip to Texas.
subi8612stpr 06-28-2018 10:03 PM
Bringing back a thread from the dead. In case anyone is figuring out to fit VP racing jugs in a 86 for track days and like me you’re not comfortable laying them on their side. You can fit 4 upright 5 gallon jugs, with the backseat folded down and then a bungee cord around them to keep them from moving.
Trueweltall 06-29-2018 11:06 AM
Jerry Cans work and they don't care which way you lay them. You can runs these over and they won't leak.
https://deutscheoptik.com/images/products/13850.jpg
https://deutscheoptik.com/20-liter-j...t-of-four.html
