Old 02-04-2015, 06:44 PM   #15
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by swarb View Post
I have a set of coilovers. Would top hat spacers made from hdpe would reduce some nvh? I am looking at the 1/4" type.
http://www.subtle-solutions.com/inde...28bab237f31f80
Are you running stock suspention?
1974 TA22 Celica
2013 86 GT
Old 02-04-2015, 06:50 PM   #16
swarb
Can you read what you quoted? suspenSion
Old 02-04-2015, 06:54 PM   #17
makinen
makinen's Avatar
Drives: Toyota 86
What setup/purpose did you use them for?
They are softer than steel or aluminum. Maybe they will isolate some noise.
I use them because of ride height.
Yeah, HDPE is softer than AL, but not enough to give comport from that thin 1/4" pad. To say, 2% enhancement in harshness?
makinen is offline   Reply With Quote
Old 02-04-2015, 07:52 PM   #18
Turdinator
Señor Member
Turdinator's Avatar
Apologies. I shouldn't comment on forums before having a coffee in the morning.
What sort of top hats do the coilovers have? If they are solid could you replace them with rubber ones, either stock or group N?
1974 TA22 Celica
2013 86 GT
Which frontpipe to reduce drone? edeekeos Engine, Exhaust, Transmission 14 04-28-2016 02:36 PM
Reduce wheel gap without lowering the car? retrosmiths Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-29-2014 04:34 PM
Reduce under the hood temps? sw20kosh Tracking / Autocross / HPDE / Drifting 24 01-24-2014 08:35 AM
Reduce interior sound KillionsFRS Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2013 05:23 PM
what's your solution to reduce the wheel well gap? chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 01-14-2013 09:25 AM
