Old 02-03-2015, 02:55 PM   #1
swarb
Top hat spacers to reduce NVH?
I have a set of coilovers. Would top hat spacers made from hdpe would reduce some nvh? I am looking at the 1/4" type.
http://www.subtle-solutions.com/inde...28bab237f31f80
Old 02-03-2015, 03:10 PM   #2
V3rtigo
Drives: 2006 S2000
Any reduction would be minimal.
V3rtigo is offline   Reply With Quote
Old 02-03-2015, 05:21 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
If you can run the stock tops it might reduce some of the noise.
The Following 2 Users Say Thank You to Calum For This Useful Post:
DAEMANO (02-04-2015), Racecomp Engineering (02-04-2015)
Old 02-03-2015, 05:26 PM   #4
vroom4
Im going to build some for my rears out of a few sheets of toolbox liners...whenever I have to pull them off again.
vroom4 is offline   Reply With Quote
Old 02-03-2015, 06:13 PM   #5
was385
Drives: MT WRB BRZ Limited, 2007 911s
I kind of want those just for my winter setup...
was385 is offline   Reply With Quote
Old 02-03-2015, 11:56 PM   #6
makinen
makinen's Avatar
Drives: Toyota 86
I got those spacers.
They are not soft to match your wish.
makinen is offline   Reply With Quote
Old 02-04-2015, 01:20 AM   #7
swarb
What setup/purpose did you use them for?
They are softer than steel or aluminum. Maybe they will isolate some noise.
Old 02-04-2015, 07:50 AM   #8
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
They are 6061 aluminum. Says so right in the discription. I've never seen spacers do anything to reduce NVH.
Why are you trying to reduce it? Did you install aftermarket bushings?
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 02-04-2015, 08:47 AM   #9
sam69
Drives: GT 86
If you are looking at these ones ....... http://www.subtle-solutions.com/prod...28bab237f31f80 they are HPDE which is high density poly ethylene which is still pretty dam hard .
I don't think it would achieve what you are looking for you would most likely be better off with a medium density Poly Urethane .
sam69 is offline   Reply With Quote
Old 02-04-2015, 08:50 AM   #10
vroom4
If someone finds a material and does a solidworks drawing, we can have them laser cut with 0 turnaround time no problemo.
Old 02-04-2015, 09:01 AM   #11
Calum
That Guy
Hockey pucks?
Old 02-04-2015, 09:40 AM   #12
vroom4
That would be the least efficient production ever haha.
Need a decently large sheet of something.
The Following User Says Thank You to vroom4 For This Useful Post:
Calum (02-04-2015)
Old 02-04-2015, 11:08 AM   #13
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
http://www.rubbersheetroll.com/epdm-...-strength.html
Kotu100 is offline   Reply With Quote
Old 02-04-2015, 04:57 PM   #14
vroom4
and a solid works file. Not enough profit for me to do the work, but wouldn't mind helping some people out for a one off run since we have access to a giant laser cutter.
Which frontpipe to reduce drone? edeekeos Engine, Exhaust, Transmission 14 04-28-2016 02:36 PM
Reduce wheel gap without lowering the car? retrosmiths Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-29-2014 04:34 PM
Reduce under the hood temps? sw20kosh Tracking / Autocross / HPDE / Drifting 24 01-24-2014 08:35 AM
Reduce interior sound KillionsFRS Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2013 05:23 PM
what's your solution to reduce the wheel well gap? chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 01-14-2013 09:25 AM
