Drives: 2013 Black FR-S
Reduce under the hood temps?
Site Moderator
Drives: Stuff
Are you trying to reduce intake temps or underhood temps? IMO his testing is flawed, the intake temp is mostly based on the air it's picking up and will go down with moving. If underhood temps, mount temp probes around the engine bay and do some repeatable testing.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
I'm assuming the op's intake manifold is getting heat soaked in the thread link you posted.
You could probably achieve the same with a hood with vents. Of course that would be more expensive and won't stop rain from entering. |
Because compromise ®
Drives: Red Herring
If you are chasing lower under hood temperatures Robispec says
in reference to this: |
| The Following User Says Thank You to Captain Snooze For This Useful Post: | sw20kosh (11-12-2013) |
Drives: Scion FR-S/ Subaru BRZ
is your car overheating? Is heat soak effecting your supercharger?
if the answer to both is no....then WHO CARES.....sure in theory its better, but 10c (20F) drop isn't that big of a deal...... The stock cooling system in my FRS works really well, no issues even in 105F days at Thunderhill.....even with the AC on in the hotpit.....car ran perfect... |
I will be trying a different thermostat soon
#7 | |
Get a vented hood if you need to lower temps. We can help you with that. We're also testing a CSG radiator
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | AceHeader-MT (11-26-2013), ZionsWrath (11-16-2013) |
Drives: Red Herring
What's the deal with venting a hood then having water, dirt, bird poop flowing down the vents when parked in the rain? Is that the trade off for venting the hood?
Grip>Drift
Drives: FRS
It's not ideal on a DD.
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | Captain Snooze (11-17-2013) |
#10 |
Drives: Asphalt 2013 FR-S
Since a vented hood isn't ideal for DD, I'm curious if anyone perhaps has a separate track only hood? Kind of like how many people have a separate set of track wheels & tires and track only brakes that they put on for track days. Obviously a vented hood isn't going to fit in the trunk of the car along with your spare wheels and equipment, but you could always switch out the hoods at home before leaving for the track event. That way you get you extra the cooling and downforce at the track where you need it, and the rest of the time you stick with your stock hood for DD where you get the protection from the elements.
I would think that swapping out hoods should take no longer than swapping out a set of wheels. I have a buddy who only puts on his rear spoiler for track days, which is probably no more than a dozen days out of the year. Sure we all love our cars and look for any excuse to go canyon carving, but in our normal DD I would think that a non-vented hood would still be ok for most of us. I'm not FI and I live in beautiful Santa Barbara CA where it's never too hot or cold. So I don't know, maybe a vented hood is a necessity if you're FI and in Texas or Arizona. Here in Santa Barbara though, the weather is nice but we got a lot of trees. So there are a lot of leaves and crap flying around in the air that get stuck in the wiper area of the car. I definitely don't want that stuff getting into the engine bay. There are enough smells coming from there as it is. |
#11 | |
Either way, it hasn't been a big deal in my experience. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Captain Snooze (11-17-2013) |
#12 |
Drives: Red Herring
I must admit to being a little in lust with Robipec's vented hood
#13 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
@omegared19 has Prova vents installed an cut out the inside. Dropped engine bay temps significantly he said.
#14 | |
Drives: 2012 FR-S
Yes, it does help temp drop temps when park and sit in the pit lane. Can you tell me how to test the "reducing airflow through the radiator."? I would like to test it. Thank you Ace |
| Product To Reduce Dash Glare? | Captain Snooze | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 08-20-2015 06:55 PM |
| Reduce wheel gap without lowering the car? | retrosmiths | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-29-2014 04:34 PM |
| Reduce interior sound | KillionsFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 10-28-2013 05:23 PM |
| what's your solution to reduce the wheel well gap? | chenshuo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 01-14-2013 09:25 AM |
| Petition to Reduce Grey Market Imports from 25 to 15 years! | chulooz | Other Vehicles & General Automotive Discussions | 3 | 12-05-2011 11:59 PM |
