View Poll Results: Best Lower Control Arms?
Stance 33 14.60%
Whiteline 32 14.16%
Cusco 51 22.57%
SPC 34 15.04%
Megan Racing 4 1.77%
GTSpec 4 1.77%
ISC 8 3.54%
DME 1 0.44%
Agency Power 1 0.44%
None of the above (post reply of other product) 58 25.66%
Voters: 226. You may not vote on this poll
Old 01-28-2015, 11:11 AM   #29
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I'm going to say whiteline, because spherical mounts bump me out of stx.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
JohnJuan (01-28-2015)
Old 01-28-2015, 02:29 PM   #30
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Originally Posted by Koa View Post
RacerX with urethane for non track seems like a challenger to SPL as well! I don't track this baby yet but I love mine.
RacerX is fine for just camber adjustments but doesn't come close to the adjustability to the SPL which has multiple sway bar link holes and lower shock mounting holes. I drive mine on the track a lot so the additional adjustment features on the SPL were a must have for me. I haven't found another LCA with comparable adjustability, tuning, features.
Sleepless is offline   Reply With Quote
The Following 2 Users Say Thank You to Sleepless For This Useful Post:
CSG Mike (01-28-2015), Koa (01-28-2015)
Old 01-28-2015, 02:42 PM   #31
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Whiteline cuz they're so dam pretty!
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 01-28-2015, 02:42 PM   #32
DAEMANO
Time Traveller
Powered By Max LCA's
Lowering like Stance LCAs but with two positions (20mm and 45mm lower)
Designed, and tested by PBM (this is huge).
CHEAP -$220 a pair.
http://www.partsshopmax.com/page.php?59
The Following User Says Thank You to DAEMANO For This Useful Post:
dobbrz (02-03-2015)
Old 01-28-2015, 03:06 PM   #33
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
What about Flatwell LCA? They are used on the RS-R Formula D 86
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 01-28-2015, 03:43 PM   #34
CSG Mike
CSG Mike's Avatar
But they're solid.
Old 01-28-2015, 05:19 PM   #35
DAEMANO
Time Traveller
RS-R is also selling Rear LCAs - $525.00
http://www.rs-r.com/product/rs-r-rea...-control-arms/
http://www.fteightysix.com/new-produ.../#.VMlgbaOQc1s
Old 01-28-2015, 09:21 PM   #36
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
FWIW the latest rev of SPL arms have even more adjustability.
Decay107 is offline   Reply With Quote
Old 01-28-2015, 11:40 PM   #37
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I've always wondered why the SPL LCA's don't have any cross bracing like every other LCA on the market. Are cross braces needed or not for rigidity?
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 01-28-2015, 11:49 PM   #38
Black Tire
Black Tire's Avatar
But they're solid.
Not so $$$$$$ according to this source:
Flatwell LCA's at RHD Japan
Old 01-28-2015, 11:51 PM   #39
liquidsky44
Reasonable price and the shipping cost to where I am is pretty good.
Old 01-29-2015, 12:15 AM   #40
Decay107
Decay107's Avatar
Theoretically, there shouldn't be much torsional force about the center-line or shear force across the center plane. Also once the shock and sway bar are bolted up and torqued, they effectively add to the overall rigidity.
Old 01-29-2015, 11:02 AM   #41
Jonsey
Jonsey's Avatar
I think that is exactly right. If you look at where the shock and sway bar mount, they effectively split the open span into 1/3s with only a few inches between each span, which should be more than strong enough for the minimal forces the LCA will see in that direction. Also, I am not sure of the material used for other LCAs, but the SPLs are titanium, which could contribute to the lack of cross bracing required.
Jonsey is offline   Reply With Quote
Old 01-29-2015, 11:15 AM   #42
Decay107
Decay107's Avatar
It's actually machined 6061for the main body, only the hardware is titanium.
The Following User Says Thank You to Decay107 For This Useful Post:
Jonsey (01-29-2015)
