Old 01-24-2015, 04:45 PM   #1
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Rattle after front pipe install
Just installed a tanabe front pipe but I hear slight rattling when I rev the car. Where could it cause this issue? I read about lifting the pipe and tightening?
One bolt from the over pipe snapped too but luckily I still had enough threads for replacement nut.
Edit: problem solved. Over pipe got slightly moved during install. Wiggling it around got it back to no rubbing the subframe
Decimus is offline   Reply With Quote
Old 01-25-2015, 01:49 AM   #2
jflogerzi
jflogerzi's Avatar
Could be the over pipe hitting the subframe?
The Following User Says Thank You to jflogerzi For This Useful Post:
Decimus (01-25-2015)
Old 01-25-2015, 05:24 AM   #3
Mike Brz
Does it have a badge on it. My j2 downpipe had a badge it was rratteling cause the welds broke
Mike Brz is offline   Reply With Quote
The Following User Says Thank You to Mike Brz For This Useful Post:
Old 01-25-2015, 11:49 AM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Possibly, I searched more and I think maybe the over pipe is slightly misaligned so going to try to move it and tighten down the front pipe hangar bolt
Nah didn't have a badge. Good looking out though
Old 01-25-2015, 12:05 PM   #5
HotRodPA
Did you reuse the OEM dounut the slips on the downpipe? Forgetting that step caused a rattle in my car. Good luck!
HotRodPA is offline   Reply With Quote
The Following User Says Thank You to HotRodPA For This Useful Post:
Old 01-25-2015, 02:50 PM   #6
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Problem fixed! Went under the car again and loosened the front pipe hanger and trial & error until I found the "sweet spot" with no metal on metal. It was definitely the over pipe touching the sub frame. Thanks everyone!
The Following User Says Thank You to Decimus For This Useful Post:
HotRodPA (01-25-2015)
Old 01-25-2015, 05:03 PM   #7
jflogerzi
jflogerzi's Avatar
Perfect.
Any NY'ers install catless front pipe? ShoNUFF NY / NJ / CT / PA 19 01-04-2015 08:30 PM
Berk HFC Front Pipe install questions ronboogieon DIY (Do-It-Yourself) Guides 3 11-08-2014 12:40 PM
cel after front pipe install assbox Engine, Exhaust, Transmission 18 11-26-2013 02:02 PM
Catless front pipe install? bdanisi Southern California 7 08-22-2013 08:26 PM
Assistance on DIY front pipe install. Osiris DIY (Do-It-Yourself) Guides 3 04-18-2013 10:31 PM
