Old 12-21-2014, 03:06 PM   #827
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
Originally Posted by MokSpeed View Post
Okay noob question, but when it states to turn the key to ignition does that mean to start the car up as well?
Turn the key to the ON position, do not start the car.
menikmati is offline   Reply With Quote
Old 12-23-2014, 10:13 AM   #828
vgi
Drives: frs
@Shiv@Openflash
hey shiv, i'm curious if the OFT locked tunes ever got opened (eg OFT300, SBD - i remember there were some heated arguing on locked ecutek vs opened OFT tunes)?
vgi is offline   Reply With Quote
Old 12-24-2014, 03:02 PM   #829
sirsol66
Drives: 2013 FRS- Hot Lava
Shiv, can you provide some feedback for this? Several people have had this issue on the OFT tunes.
http://www.ft86club.com/forums/showt...=1#post2067575
sirsol66 is offline   Reply With Quote
Old 12-24-2014, 03:25 PM   #830
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
Ive been having a similar issue, but the car is already warmed up. (15 min of driving after initial warm up)
Ive had the stage 1 91oct - 1.59, 2.00 and now the ESC tunes and the car hesitates once in a while at WOT @ 4-5k rpms especially when I'm going ip a hill.
The only thing changed prior to any tune was the cat back Perrin exhaust, which did not contribute to any "misfiring" prior to tunes.
I'll have to send the file to someone and have them look at it since i don't have much experience with reading data logs.
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is online now   Reply With Quote
Old 12-24-2014, 11:32 PM   #831
ScionFrsFan
Is there anything "special" the OFT could do to a automatic. I love my OFT...but could it change the way a auto shifts, ect be changed? Thank you!
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 12-25-2014, 12:44 AM   #832
s2d4
s2d4's Avatar
Manual paddles.
The Following 2 Users Say Thank You to s2d4 For This Useful Post:
tonystewart (12-25-2014), Wayno (12-25-2014)
Old 12-25-2014, 02:31 AM   #833
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Shittons:
Copy the throttle map from MT - this will save you fuel on E85
Add the soft rev limit same as MT
Use the paddles
The Following User Says Thank You to Wayno For This Useful Post:
Old 12-31-2014, 06:20 PM   #834
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by vgi View Post
@Shiv@Openflash
All OFT300, SBD, Phantom tunes that we have been providing since early this year (2014) have been unlocked (.bin format). As a matter of fact, I can't even remember the last time I sent out a FI tune file in .dev format.
Shiv@Openflash is offline   Reply With Quote
Old 12-31-2014, 07:44 PM   #835
pl1ght
Drives: 2015 Alfa Romeo 4C
So I got my OFH in, no probs. Flashed to with OFT 93 stg2 UEL. Still getting a p0037 and p0031 CEL, is that right? Thought the CELs should be cleared by tune?
pl1ght is offline   Reply With Quote
Old 12-31-2014, 07:56 PM   #836
steve99
Drives: FT86
The code for cat efficiency is P0420.
The codes your getting are for 02 sensor heating circuit failed
iether the 02 sensors have been damaged or not plugged in correct sockets, they are colour coded plugs grey and black.
they should screw in by hand then tighten to required torque. its best to use a tread tap or chaser to clean the threads up before inserting , 02 sensors are easily damaged if you apply heaps of force
Shiv@Openflash (12-31-2014)
Old 12-31-2014, 07:59 PM   #837
Shiv@Openflash
Drives: 2013 FRS
Those are o2 sensor header control circuit codes. Those codes are bot turned off/disabled by the tune. I don't think you should be getting those with the header. if you clear them, do they come back?
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
pl1ght (12-31-2014)
Old 12-31-2014, 08:20 PM   #838
pl1ght
yes, i am still getting them after clear.
Old 12-31-2014, 08:22 PM   #839
pl1ght
Wow, i HATE to admit this, i forgot to plug them back in to the car, FFS.
Happy new years. Had an epiphany right this moment.
The Following 2 Users Say Thank You to pl1ght For This Useful Post:
flippy (01-05-2015), steve99 (12-31-2014)
Old 12-31-2014, 08:37 PM   #840
Shiv@Openflash
Drives: 2013 FRS
Happy New Year!
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
