Old 08-07-2014, 01:40 PM   #15
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Originally Posted by wheelhaus View Post
Are you seeing problems on the newer cars or is it still the older ones trickling in? I was under the impression it was largely resolved because the megathread and other similar threads seemed to die and became much less frequent Most owners were saying it had been fixed and hadn't come back, and those who did have recurring problems were treated with random replacement parts before the TSB, i.e. no ECU etc.
If this is still a current problem, do you have any insight to the root cause? Mine was first gen mfg'd in mid 2012 and my idle is rock solid after 13k miles and some track days...
Most of them are the OCVs and there has never been a revision to them. I am replacing a cam actuator on one this week whenever the part comes in. Yes, both old and new models. One of the "fixes" was a revision on the tune to essentially allow for a larger margin of error for cam phasing faults but even with the newer ROMs it's still happening and its because the cams really are going way out of phase with one another. Whats causing the failure of these components (OCVs and Actuators)? I don't know. They briefly have blamed oil viscosity and replacement intervals but that's BS because the majority of failures have been good oil and the correct viscosity. The parts are all of course non-serviceable so tearing them apart basically ruins them. Electrically all the OCVs I have had issues with test good so not likely an issue there. It seems to also almost religiously be the exhaust cams suffering the most failures but no surprise as they are the ones working much harder than the intakes. The intakes are rather stagnant (meaning they don't really advance and retard as much).
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
wheelhaus (08-07-2014)
Old 08-07-2014, 11:03 PM   #16
nivek111070
Drives: 2014 GB Scoobie BRZ
WELL, they finally got it "fixed" told me that some dog biscuit looking shim that is on the back of the cam cam off and was rolling around , they replaced the ecu as well. I do know that the surging while driving in 1st at low speeds and the up and down idle problems are no longer there.
nivek111070 is offline   Reply With Quote
Old 08-14-2014, 08:10 PM   #17
monkeedoo
Senor Member
monkeedoo's Avatar
Drives: ME CRAZY
add me to the list same thing yesterday theyre pulling codes, may replace cam, and they are in contact with corporate anyone have this successfully resolved?
monkeedoo is offline   Reply With Quote
Old 12-16-2014, 03:54 AM   #18
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Is there anyone I can talk to who can help me get this problem fixed on my car? I've had my car in the dealership but because i am modded they don't want to help me. I have the surging at low speeds and the check engine light with dip on deceleration. I know this is not caused by my mods... How can i fight this?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 12-16-2014, 10:00 AM   #19
wheelhaus
wheelhaus's Avatar
First question, are they refusing to work on your car because they don't want the liability of working on a customer's modified engine, or are they treating it as a voided warranty claim and saying you have to pay? Those are two completely different circumstances.
Have you communicated with them that this is a known problem and shown them the TSB? If you're being polite and professional, and they still refuse the work altogether, I'd get in touch with some other dealers to see if they will support it.
If you're not having any luck, see if any dealers would support the parts exchange for the updated parts, and then find out what some local garages with FRS/BRZ engine experience would charge to install them.
Old 03-18-2015, 09:20 AM   #20
dchoochew
Drives: 2015 Red FRS
Add me to the list as well. Had the check engine light + my cruise control lights lock up on my dash at around 4K and they told me the cam position sensor triggered it. They cleared it and told me to drive the shit out of it.
I'm at around 6500 miles now. Drove to work and my check engine + traction control came on with idling issues. Dealership said to just bring it in and they would take another look at it.
dchoochew is offline   Reply With Quote
Old 03-18-2015, 10:03 AM   #21
BRZnut
Drives: BRZ DGM Limited
Let us know what they find. Would have thought they would have worked out the bugs in the 2015 builds!
Old 03-18-2015, 10:53 AM   #22
dchoochew
You would think that! Dealership told me last time that another girl was bringing her 2013 one in for the same problem every 8K miles.
I'll definitely let you know what they find.
Old 03-19-2015, 09:28 AM   #23
dchoochew
Went to the dealership yesterday and the code that popped up was P00B (Cam position sensor). Not the first time this code has popped up on my car.
Going to get it replaced along with my ECU reflashed.
Old 03-19-2015, 09:34 AM   #24
Reading through here this is probably one of the most common codes that get thrown! There is a TSB for it I believe.
Old 10-15-2015, 12:43 AM   #25
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
After reading around this sounds like what happened to my car. I have over 40k miles, though, a modded engine, and no warranty. Would it be best to just let a shop take a look at it or take it to toyota?
MS, CSCS, TSAC-F, CPT
Old 01-18-2016, 02:49 PM   #26
Astroboy
Astroboy's Avatar
Drives: None
How much is the cam gear? Do you know which one in particular it could be? The one closer to Piston 2 bank A
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 03-13-2016, 01:00 AM   #27
Morphus1
Drives: GT 86
What is this TSB and where do I get it?
Modified engine, same goes, Had small idle issues since purchase that have manifested into Stalling when the rev's drop. Car is undriveable in traffic.
Morphus1 is offline   Reply With Quote
Old 03-13-2016, 10:28 AM   #28
BRZnut
Any new ideas on why the cams go out of whack in our twins? Anyone come up with a true fix??
Abs and Traction Light nabil_frs Issues | Warranty | Recalls / TSB 14 07-09-2015 10:39 AM
CEL and Traction Light came on today myjobis2pimp NY / NJ / CT / PA 9 10-05-2014 02:45 AM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-05-2014 12:27 AM
lowered car and traction control light came on Shipwreck Issues | Warranty | Recalls / TSB 2 11-05-2013 06:18 AM
CEL ABS and Traction Light DieselxIndustry Issues | Warranty | Recalls / TSB 3 01-31-2013 02:04 PM
